All-Screen Keyboard Has Flexible Layouts
Most keyboards are factory-set for a specific layout, and most users never change from the standard layout for their home locale. As a multilingual person, [Inkbox] wanted a more flexible keyboard. In particular, one with the ability to change its layout both visually and logically, on the fly. Thus was born the all-screen keyboard, which can swap layouts on demand. Have a look at the video below to see the board in action.
The concept is simple enough: It’s a keyboard with transparent keys and a screen underneath. The screen displays the labels for the keys, while the transparent plastic keys provide the physical haptic interface for the typist. The device uses a Raspberry Pi to drive the screen. [Inkbox] then designed a plastic frame and transparent keys, which are fitted with magnets, which in turn are read by Hall effect sensors under the display. This eliminates the need for traditional key switches, which would block light from the screen below.
Unfortunately for [Inkbox], the prototype was very expensive (about $1,400 USD) and not particularly functional as a keyboard. However, a major redesign tackled some of these issues. Version two had a smaller screen with a different aspect ratio. It also jettisoned the Hall effect sensors and uses plastic keys capacitively operating a traditional touch screen. Some design files for the keyboard are available on Github for the curious.
An all-screen keyboard is very cool, if very complicated to implement. There are other ways to change your layout that aren’t quite as fancy, of course. You can always just make custom keycaps and remap layouts on a regular mechanical keyboard if desired. Still, you have to admire the work that went into making this thing a reality.
29 thoughts on “All-Screen Keyboard Has Flexible Layouts
  1. As someone who switches between the Greek and English alphabet on the fly, this would be useful, although I have pretty much memorised the position of the Greek keys so is really not that much of a problem.
    The only proper solution here is a tiny screen on top of each key that can be changed. An e-ink screen would be best.
    1. These remind me always of the amazing Optimus Keyboard by artlebedev :D -> https://en.wikipedia.org/wiki/Optimus_Maximus_keyboard which has the single screens per key.
      I would love one with e-ink (either in the caps or as the whole backscreen as well) as well. have recently looked into it, but e-ink screens are not available in a variety of ratios it seems.
      (btw: If anyone has knowledge about something like an e-ink strip (i.e. 5-10mm high, 100-200mm wide display) i would love to know about it)
      1. Yep, that one was available for pre-order in the early 2000, if I remember right, 2003. Don’t know if anyone bought these, though, back then +$1K was a lot of money, so only bill gates could afford one with ease.
        Sadly, we ARE moving away from what should have been invented and built instead – a keyboard where each key is the eInk display. Not sure what’s taking THIS insanely long to invent the obvious, the price of average tiny eInk display has dropped from the stratosphere (where it still was in the early 2000s) back to my level of food chain.
      2. At the time, anything Russian was often affiliated with organized crime. We were once interested in using a disposable cell phone as an incentive from a similar design firm in Russia. We looked up the history, no way, not going there. It was really unfortunate.
    2. Each key being its own display is going to be vastly more expensive, and this system is way more flexible, and could actually be done with e-ink if you really wanted too.
      But that ability to create a new key overlay on the same screen for other physical key layouts relatively affordably to me makes this system the winner – so that simulator cockpit could have a few button layouts to match the game/aircraft, can have ergonomic layouts, only using half the screen for keys so you have a more useful bit of screen real estate and potentially a Pen input (software permitting) etc.
  2. An interesting concept. I remember working with one of the first PC word processing applications that used the plastic overlays to display keyboard shortcuts and several years ago I was talking to a neighbour in the broadcast industry where they used different overlays for different applications and was a pain switching them out. This would be a great option for those applications.
    1. decades ahead of its time. I am absolutely shocked they were able to source small enough screens back then. tho the keys were slightly larger than normal. now we have all this fancy custom cut glass and even non rectilinear displays. would be cool to see another attempt at the idea instead of just putting keycaps in front of a display.
  3. If the keys were instead made of fiber-optic plate or ulexite, the image would appear on the top edge instead. Ulexite actually seems relatively affordable, but might be pretty difficult to manufacture it into keycaps.
  4. Reminds me of the keyboards from Design Studio Art Lebedev, some 15-20 years ago. Tactus, was a design, necer realised but with a huge touch screen. And there was model Optimus Maximus which had over 100 individual screens mounted in each key.
    1. You don’t have to be part of that we if you don’t want to.
      You can type on whatever keyboard layout and map you desire. Try a 40% ortho board. Build a split. Make your own keymap that’s Colemak but rotated down and to the left by one. With cheap custom PCBs, 3D printing, and an all-you-can-eat buffet of open source keyboard firmware options, there’s no reason you have to be stuck with classic staggered QWERTY.
    2. Absolutely! Not to go Maltron etc. but why the broken in two angle which was a poor choice of lining up the keys instead of a single angle like Linotype and flipped for the other hand. In a word “looks” had to excel over function. You can’t have the small gap in the middle, cleavage. This of course was because one proprietary design took over without a thought. This was at a time when tiller steering and hand lever brakes were on cars. Good enough.
  5. IBM Selectric electro-mechanical typewrters had a similar problem: each new type element (golf ball) really wanted new keycaps… or stickers for the keys… to reflect the change in output. Mentally switching between, say, a Courier text layout and an APL programming layout took some getting used to.
    Yes, a display-screen-per-key keyboard wold be nicer than stickies, but it seems likely that it would affect the “feel” of the keys at the same time. Same problem with those “laser projection” virtual keyboards: they offered a remarkably flexible display, but I found it hard to get used to “pressing” on a tabletop and getting no “feeling” from my “keystrokes”.
    How abou a combination? A set of keybuttons — real pressable items, perhaps even with mechanical clicks — but totally blank, and with their legends set by a projection from overhead? Yes, the fingers would block some of the projection, but touch-typists probably wouldn’t be looking at the keytops very often, and slower typists (I’m working my way up from three to four fingers) could have the current layout mentally refreshed simply by moving their fingers slightly. Plus, the keytops would be readable even in dim light, something not true with even beautifully-silkscreened all-machanical keyboards.
    Jes’ a thought.
  6. Low-cost ~$20- small desk space keyboards now appearing on Amazon.
    Use with $130- Windows 11 laptops running 11, Ubuntu, and 10 1909 along with ~$100 tv/monitors
    for nanocomputer software development economical?
    Two major keyboard layouts?
    1 Right column Home, pgup, pgdn, end.
    2 Left arrow [ctrl+fn?] home], arrow uip line or page up, arrow down line or page down … or end.
    BUT both using bright LED to indicate caps on/off!
    Human factors/UX very important in keyboard design?
Leave a Reply to joyfully8db34ef3cdCancel reply
