Look inside a science fiction computer, and you’ll probably see tubes and cubes that emit light. Of course, it’s for effect, but the truth is, people do think light computing may be the final frontier of classical computing power. Engineers at the University of Southern California Information Sciences Institute and the University of Wisconsin-Madison are showing off a workable photonic latch — a memory element that uses light.
The device uses a commercial process (GlobalFoundries (GF) Fotonix Silicon Photonics platform) and, like a DRAM, regenerates periodically to prevent loss of the memory contents.
On the device, you’ll find a combination of tiny photodiodes, micro-ring resonators, and optical waveguides. Simulations show the memory element can operate at 20 GHz and might even be readable at 50 or 60 GHz.
If you want to dive deeper, the work is based on a paper from earlier in the year.
First steps to isolinear rods
Just make sure you’re wearing your Isotoners.
What’s taking so long, btw.
“Look inside a science fiction computer, and you’ll probably see tubes and cubes that emit light.”
https://ntrs.nasa.gov/citations/20190030489
For some reason, title of the article made me think of using a light based version of delay line memory.
The internet says the SFH 203 P photo transistor has a switching time of 5ns. So 5 feet gets you one bit. That’s quite a lot of optical fibre to coil up. Still, there’s no reason why not. There’s always that mirror on the moon, weather permitting.
This may be wrong but some quick maths suggests 946969 miles per gigabit.
The “1 foot in 1ns” is for light at the speed of C, aka in a vacuum.
Here on earth light travels slower than C when we inconvenience the photons by sending them on an adventure through glass and plastics and such.
It’s about 7 inches per 1ns in a 50/125 multimode glass fiber optic cable for instance.
Sabine H made a video just recently about optical computing and mentioned memory as the major hurdle… which is now overcome?
It’s not, and Hassenfelder is just another clickbait fraud, I suggest curating your intake a bit better. Why? She frequently pushes outright misinformation mixed with nice sounding but poor coverage of science, and is literally paid to do so.
What is the name of your channel that is free of misinformation and poor coverage?
I find Sabine’s signal-to-noise ratio better than most for what she covers.
Photonic computing is always going to be a problem looking for a solution.
Photons are expensive per bit, energetically speaking, and (as the article says) they take up a lot of space. Any optical computing device will be large and power hungry, with no prospect to reduce either problem.
There are and will be niche applications where they perform really well (clocks, long-haul interconnects, some kinds of pattern matching and identification), but as a replacement for a general-purpose CPU or RAM? Nope.
I wouldn’t call any of that “niche”, and certain board interconnects are not a terrible use, just as optoisolation is common now. Also, both noise generating and susceptible circuits can benefit even if there are other losses. It just depends on the actual uses, which of course hype isn’t useful for.
Why do you say power hungry?
Can I have it installed in my optic nerves and brain?
I’m getting old and I forget words…..sucks.
Sadly none of this has much to do with your needs, or mine. That said, a neurological interface for both aren’t incredibly far off, just tested medical versions of them.
I am guessing that the glowing SF computers originated back in the days of tube logic, when there really was a glow, and then that changed colors to indicate advanced stfnal technology. Although most modern PCS that glow just do so for bling factor, in an experimental or critical machine having status LEDs inside the box for quick debugging and repair guidance might not be a bad idea.
My MB has that to tell where it is in the boot cycle.
I would have mixed feelings seeing Cherenkov radiation coming from my computer…
Somewhere between “Cool!” and “Uh-oh!”
Still don’t get it, why not custom-make diffraction grating/gratings in such way that shining laser from certain angle/angles would return certain binary pattern? Better yet, since it is analog, shining laser from certain angle/angles results in MULTIPLE patterns that can be read using multiple wavelengths sensors simultaneously. Furthermore 3-D print gratings in layers AND print them in patches, like a QR code, so the pattern of the QR codes themselves, too, resolve to a pattern?
Buzzwords not, diffraction gratings are used in the spectrography and the technology itself is 100+ years old by now, back then it was etched by hand, using the best microscopes available, by now ordinary 3D printer can probably deposit crude grating with somewhat similar resolution (if I remember right, gelatin was used back then, with about the same challenges facing 3D printers today, instability, etc).
I think THAT’S how cardassian isolinear rods were made, not? At least I would fathom they had stacked layers that a reading laser would be reading through using different angles. This much makes sense (to my limited brain).
