Active Ideal Full Bridge Rectifier Using TEA2208T
Everyone loves a full-wave bridge rectifier, but there’s no denying that they aren’t 100% efficient due to the diode voltage drop. Which isn’t to say that with some effort we cannot create an ideal bridge rectifier using active components, as demonstrated by [Mousa] with an active bridge circuit. This uses the NXP TEA2208T active bridge rectifier controller, along with the requisite four MOSFETs.
Comparing a diode bridge rectifier with an active bridge rectifier. (Credit: Mousa, YouTube)
Taking the circuit from the datasheet, a PCB was created featuring four FDD8N50NZ MOSFETs in addition to the controller IC. These were then compared to a diode-based bridge rectifier, showing the imperfections with the latter when analyzing the output using an oscilloscope.
As expected, the active rectifier’s output was also one volt higher than the diode bridge rectifier, which is another small boost to overall efficiency. According to NXP’s product page, there’s about a 1.4% efficiency gain at 90 VAC, with the chip being promoted for high-efficiency operations. When you consider that many designs like computer PSUs feature one or more diode bridge rectifiers often strapped to heatsinks, the appeal becomes apparent. As for [Mousa], he put this particular board in his laboratory PSU instead of the diode bridge rectifier, because why not.
Perhaps the biggest impediment to using an active rectifier is the cost, with the TEA2208T coming in at $4 on DigiKey for a quantity of 100, in addition to the MOSFETs, PCB, etc. If power efficiency isn’t the goal, then some wasted power and an aluminium heatsink is definitely cheaper.
22 thoughts on “Active Ideal Full Bridge Rectifier Using TEA2208T
    1. That nerd burn is so sick it heats the PCB until all components are dropping off.
      (The tin fumes are a bonus sick “burn” to the nostrils.)
      Not sure if there’s any substance to it but whatever.
  1. “Perhaps the biggest impediment to using an active rectifier is the cost, with the TEA2208T coming in at $4 on DigiKey for a quantity of 100, in addition to the MOSFETs, PCB, etc.”
    Any company using this can just raise their prices and say, it’s the tariffs. Problem solved.
    1. Ok NXP, why no datasheet? No PDF with useful info, no sale. And the product would be interesting too, I would like to maybe make a bench supply with something like this. I am curious if it does SMPS active rectification.
  2. Depending on how some “ideal diodes” are implemented, they can have interesting and sometimes dramatic failure modes, like holding a switch (“diode”) closed when the source power is removed but the load power is still present (like a battery charger).
    A quick perusal of the data sheet doesn’t reveal how this IC behaves in cases like that. It appears that when input AC power is removed the control circuitry turns off all the MOSFET gates, but it also looks like it requires the load voltage to disappear too in order for this to happen.
    It also requires a curious 0.45-second reset period after power removal to reset and restart normally. What happens if that constraint is not satisfied, like everyday mains power glitches that remove power for a cycle or two during utility switchgear changes?
    It merits some extra testing before building this into a product, especially if you’re doing something unusual like redundant or multiple supplies, battery backup, battery charging, etc.
  3. Some pinball games flash their playfield illumination lights (connected to 6.3VAC) with a relay. I have been looking for a clickless solution without voltage drop, but it looks like a relay is still king.
    1. There are an awful lot of optorelays that will do that. For example, a TLP170 drops less than a tenth of a volt at 0.3A, for much less than a couple of bucks.
        1. A photorelay switches AC, no problem.
          If you don’t find one that can handle the current you need, put some in parallel. Or put one per lamp base.
          Or roll your own FET-based solution. This is not a hard problem.
        2. Try feeding DCV to a spare lamp sometime.
          Also, if the 6v3 transformer is supplying just lamps. switch it’s input (mains line voltage, at a much lower total current) using a triac or SSR.
          I don’t service pinball or arcade machines, perhaps there’s some reason this isn’t feasible, but if you’re running even a US 120Vrms input to a 6v3rms out, a 1V reduction in the input voltage is absolutely within variance in grid voltage, assuming the output voltage isn’t actively regulated, you’re looking at 6.2475V with that 1V drop in input. A gnat’s sneeze more than 50mV
  4. Triac or SSR would sort of work, but the voltage drop would be too much to keep 6.3V lamps at normal brightness. Maybe two anti parallel connected MOSFETs could work, but then driving them is not going to be easy.
    1. You can drive “two antiparallel MOSFET’s” with an isolated DC-DC converter. It’s a bit over the top, but because these things are cheap COTS, it’s still a viable solution. And there are also optomos IC’s that are designed for driving external FET’s.
    2. Or just buy a single 4-pin part that’s designed for the job. The TLP170A I mentioned above can switch a half amp. Its bigger brother the TLP3555A will handle more than two amps, still less than $3 in onesies. Not enough? Parallel them. They’re FETs. They’ll happily curent-share.
  5. The ‘ideal diode’ concept, and its design and its usage is most definitely not new; it’s as old as the operational amplifier (op-amp) itself.
    There are places in electrical engineering design for the ideal diode makes imminent sense.
    This is not one of them.
    1. I googled “low voltage synchronous rectifier” and one result was the UCC24630, Vdd = 3.6 V to 28 V.
      Another concept to steer your search would be energy harvesting, because you also have to regulate that voltage or use it to top up a battery.
      Since the chip uses very little power, you might just feed a capacitive voltage doubler with a bridge rectifier.
  6. I’m pretty sure that this does not work at all with the schematic provided. The 10k pull downs on the gate are too much for the 220nF cap to overcome at low frequencies. The reference schematic in the datasheet does not show any pull down resistors for a reason.
Leave a Reply to TuukkaCancel reply
