M8SBC-86 Is An FPGA-Based “Kinda PC Compatible” 486 SBC
Given the technical specs of the FPGAs available to hobbyists these days, it really shouldn’t be a shock that you can implement a relatively-modern chipset on one, like one for a 486 system. In spite of knowing that in the technical sense, we were still caught off guard by [maniek-86]’s M8SBC project that does just that– the proas both CPU and BIOSducing a 486 FPGA chipset with a motherboard to boot.
Boot what? Linux 2.2.6, MS-DOS 6.22 or FreeDOS all work. It can run DOOM, of course, along with Wolfenstien 3D, Prince of Persia, and even the famous Second Reality demo– though that last without sound. [maniek-86]’s implementation is lacking direct memory access, so sound card support is right out. There are a few other bugs that are slowly being squished, too, according to the latest Reddit thread.
The heart of the system is a Xilinx Spartan II XC2S100 FPGA, which serves the motherboard chipset, codnamed “Hamster I”. The CPU is a vintage i486, running at a configurable 24MHz.  The BIOS code is based on an open-source project by [b-demitri1] that’s also on GitHub, if you happen to need a PC BIOS.  The FPGA isn’t doing everything: graphics is, as right and proper for a PC-compatible of this vintage, provided by an ISA card. [maniek] has tested several VGA cards and all apparently worked equally well, so that aspect of the system is apparently well in hand. The 4MB of system RAM seems pretty reasonable for a 486 build, as does restricting peripherals to PS/2 and the aforementioned ISA bus. We might have gone for a faster clock default than 24MHz, but that’s well within historical territory. Only a few bugs and the pesky lack of a DMA controller keep this from being a true PC-Compatible build, and that’s pretty amazing for one human’s hobby project.
There’s no video of it operating, but there is a very readable hardware diagram. (Click to enlarge).
Eventually, as stocks dwindle, reproducing retrocomputers in FPGA– as was recently done with the MSX standard–may be the only way to enjoy them. That’s probably least true of the 486, which lived on for decades in industrial hardware, but that doesn’t take away from how impressive this build is.
Thanks to [sven] for the tip! Remember: if you see something, say something, because Big Hacker isn’t always watching. (We leave that to the tech giants.)
23 thoughts on “M8SBC-86 Is An FPGA-Based “Kinda PC Compatible” 486 SBC
  1. heart of the system is a Xilinx Spartan II XC2S100 FPGA, which serves as both CPU and BIOS
    No, the FPGA is not serving as CPU, there is real Intel 486DX2 on there, and does NOT serve as BIOS, there is real W29C020 serving rom contents.
    Despite using really fast SRAM instead of DRAM thus skipping designing own memory controller the speed is really really low at 17MB/s meaning cpu is running in 386 compatible mode (no burst).
    Using 5V toleant Spartan 2 was really smart!
    DMA and second PIC should easily fit inside FPGA.
    ps: nasi tu byli
    1. Lol, that is just lazy AF.
      It’s literally the 4th line in that repo’s readme.md:
      Xilinx Spartan II XC2S100 FPGA as “chipset”. Codename “Hamster 1”
      Thanks to the title literally the whole article is wrong. Unless “calling” a computer based on the chipset is the norm now.
      Hmm the git repo hasn’t been modified in the last two weeks so it can’t be that (change after writing but before posting this “article”).
      Did the AI summary function totally bug out?
    2. really lazy isn’t. I thought this looked exciting(and it still is) but theres a big glaringly obvious socket for a 486 in the very first picture. Hopefully the author will fix this “minor” issue!!!
      1. Personally, I think it’s good if the socket remains an option, though.
        The 8086 to 80286 were second sourced a lot, while the 486 was the era of the x86 clones.
        At the time, the 486 was the first profitable CPU for the mass market.
        The 386 had much fewer alternatives, by direct comparison.
        The am386 (static CMOS core), the Cyrix/Ti 486DLC and its twins, the Chips Super 386, the IBM 386/486 cores and a few more maybe.
        By contrast, the 486 platform had a dozen drop-in replacements.
        And 25 MHz was the lower, but also stable end.
        33 MHz clock speed was ideal for 486DX-33 and 486DX2-66.
      2. Maybe the FPGA could do an 386 internally and the socket remains available for a 486?
        Way back in the 90s, highly compact 386/486 Baby AT mainboards had soldered a cheap 386DX33 or 40 (plastic package),
        but also offered an optional 486 socket for full performance.
        The on-board 386 basically was like a free gift, to get the user started.
        And in most cases it did a really good job, especially if the motherboard had offered enough cache.
        1. A practical 80386 CPU clone would be incredibly difficult (if not impossible) to fit within the Spartan-II device employed in this project (Cool project by the way!). Best one might be able to hope for is squeezing in an MCL88 8088 soft-CPU inside the existing FPGA or upgrade to a XC2S200 device and try for a Next186 core instead.
          1. Oh, okay. That makes sense, thanks for the info!
            Having an 80186-ish core would be very cool, too!
            Some 80286 applications could get along with that already.
            And EMU386 might be able to make some 80386 Real-Mode applications run.
    3. That’s very obvious from the architecture diagram embedded in the post. An author must have been very sleep-deprived to make such an unforced error. Hopefully it reads with better accuracy now.
  2. The 4MB of system RAM seems pretty reasonable for a 486
    That’s okay for a start, really.
    On DOS, most games should fit into that (DOS4GW games can use swap file).
    Though I’ve seen 286es with such an amount of RAM.. ;)
    Anyway, it’s okay to boot into Windows 3.x or run Geoworks Ensemble.
    If more RAM is needed, it can be provided via memory boards on ISA bus, just like it was done with IBM AT.
    Up to 16 MB are available that way (as Exended Memory).
    EMS using bank-switching can be higher, of course (up to 32 MB as of LIM4 specs).
    1. But that being said, retro/vintage computing is more than just computer games, of course.
      And especially the 486 was part of the early multimedia, virtual-reality and internet era.
      There’s so many useful hard- and software from that time period.
      For example, about ham radio or astronomy. Or DTP, CAD, animation, Amiga music.
      Sophisticated DOS software such as JV-Fax, BayCom/PC-Com, TOP/STOP/X-Packet, HamComm, GSHPC, Hellschreiber,
      SkyGlobe, STS Orbit Plus, Predict, TrakSat, GeoClock,
      Ventura Publisher, D-Paint, NeoPaint, ZSoft Paintbrush, PC Paint, Dr. Halo, TelePaint (Splash!),
      AutoCAD R12, AutoSketch 3, Autodesk 3D Studio R3, Autodesk Animator Pro,
      Impulse Tracker, AdLib Tracker II etc.
      Just to name a few that come to my mind. There are so many!
      Time to browse through some shareware CD-ROMs from the 90s and 2000s! 😃
    2. Ham radio free/shareware for DOS can be found here, for example:
      https://www.iz3veo.it/download-dos/HamSoft/HamSoft.htm
      The website has pictures showing the programs, which give a good idea.
      These oldies are still fun to have in the ham shack,
      also because they rely on small homebrew interfaces for serial or parallel port.
      And they’re fun to build or to tinker with (since this is HaD).
      Some use a Sound Blaster soundcard audio input and output instead.
      They might be handy for testing compatibility.
      SB Pro is often being supported, but SB16 with 16-Bit and 44 KHz sampling rate is better for DSP applications.
      PS: About sound cards an music..
      The Emu 8000 synth, OPL3 and the OPL4 don’t rely on DMA, right?
      So it might be possible to have FM music in AdLib Tracker II or use an AWE card to play MOD files.
      Impulse Tracker does support AWE’s Emu8k, but also uses the SB16 DAC for more voices?
      Then there’s OPL4 synth. If it has sample RAM it can play MODs via Mod4Win, but the sound drivers and Windows 3.1x itself maybe want a DMA controller.
      Otherwise, with sample ROM, it would still be a fine MIDI synth..
      Speaking of OPL chip, the ESFM core on some ESS soundcards has a native mode that’s way beyond OPL3.
      There’s a demo, koolnESS, that’s impressive.
  3. and even the famous Second Reality demo
    I’ve long been a fan of Future Crew’s earlier Unreal demo – Second Reality is amazing, but somehow, Unreal tops it for me.
  4. Not to be offensive but I feel like I was either experiencing dyslexia or a stroke trying to read this article what gives? “Proas both cpu and biosducing”? The rest of the article was half baked and fails even the least rigorous scrutiny
  5. The article quality aside, I really encourage you to read the project writeup. It’s decently written and it’s awesome to learn from someone else’s mistakes. I got the answers to all the questions I had after looking at this project. And I learned about author’s previous homebrew computer projects which, while not as complex as this one, are also awesome.
    ps: lcamtuf i rasz_pl, moi dwaj ulubieni polscy hackerzy w jednym wątku? [tu wstaw mema “what is this, a crossover episode?”]
Leave a Reply to Valentin AngelovskiCancel reply
