Quadcopters tend to have very poor efficency because of their high disk loading. High disk loading– that is, how much weight each square meter of area swept by the propellers must carry–is almost unavoidable with conventinal quadcopters, which are controlled by throttling the four props. Make the propellers too big, and their inertia slows down that control loop, leading to stability problems. [rctestflight] had an idea to solve this, by borrowing a technology from the world of fixed-wing aviation: variable-pitch propellers.
In aircraft use, they are not new, dating back to the end of the first world war. They’re made for everything from the largest turboprops to the 75 kW(100 HP) Rotax 912. By varying the propeller pitch, you can keep the engine turning in its ideal RPM range but still vary thrust by taking a larger or shallower ‘bite’ out of the air with each sweep of the prop. You can probably see how this applies to the quadcopter: a well-designed pitch-change mechanism is going to be much quicker than throttling a big prop with lots of rotational inertia. That’s the theory.
To test it, [rctestflight] builds some large 3D-printed variable pitch props, hooks them up to regular drone motors via a belt drive, before going on–you guessed it–an RC test flight. To make that work, he’s got the pitch servo being driven from what should be the flight controller’s thrust output to each motor. Aside from the vibrations from imperfect balance on the 3D-printed props, it flies quite well– and much better with pitch control than trying to vary the RPMs of those heavy props. He’s even able to reverse the propeller pitch, making this perhaps the first quadcopter capable of autorotation. Well, almost, given that it lost control and came apart when he cut the throttle.
As for efficiency, it is exactly what you’d expect from this disk loading– so, higher than a conventional quad–even with losses from the belt drive and the high-friction surface of a 3D print. Speaking of 3D-prints, the props did hold up to the maximum RPMs he could throw at them, so no ‘kaboom’ in this video. There is a fun rotary subwoofer bonus at the end, though.
Overall, [rctestflight] thinks his variable-pitch quadcopter proves the concept, but that if you’re going to all this effort you may as well build a helicopter and have fewer points of failure. We kind of have to agree. That is how it worked out historically, after all.
This isn’t the first time we’ve seen hackers trying to improve drone efficiency– there was the hybrid ‘giant propeller’ drone a while back, and the ‘slap a wing on it’ technique featured more recently.
Let’s drive all four rotors from the same internal combustion engine now. That’s where things get fun.
I realize this is pedantic, but the Rotax 912 also comes in a 60 kW(80 HP) version, which presumably also works with variable pitch props.
well while we are picking nits,
Collective changes lift without altering RPM
Variable pitch refers to adjusting propeller blade angles to optimize thrust and efficiency across different speeds
The stingray 500 was a collective pitch quad and only had a 390w (0.52hp) motor.
TP400-D6 from Europrop International is around 8MW and it’s also connected to a variable pitch propeller. (And I’m quite sure there are bigger ones too). But I do fail to understand why it’s important in this context.
Thrust is 60kN resulting in an “efficiency” of around 0.7g/w Compare that with the 10 to 20g/W in the video (@26:01). But that does not mean much. The numbers are not comparable. Extrapolating the graph from 26:01 to the cruise speed of an A400M would make it very small. Comparing it with some commercial helicopters (which also have variable pitch propellors btw) may make some sort of sense.
And 160hp https://shop.edgeperformance.no/butikk/aviation-engines/ep-boxer-motorer
Have a look at the Boeing V-22 which has all the effort, all the maintenance problems and all the teething pains but can achieve much faster speeds than a conventional helicopter while maintaining VTOL/hover capability and will take things and people nearly anyplace more efficiently. Darn noisy though….
What would be a lot more interesting from a hacking/geekery perspective would be to have cyclic controls on a duo- or tri- copter to make them as stable as a quad without any tail rotor.
Would still suffer from vortex ring effects from rapid settling. If nearly coaxial, just a hard impact with terrain. If wide-spaced, tends to result in rolling inverted then power-diving.
Also, the V-22 isn’t “more efficient” in general, and that noise is one of the consequences. Efficiency is not loud, since loudness is a consequence of wasted energy. It is more “convenient” (in many ways), but neither fuel consumption nor other common measurements of efficiency really qualify it as “more efficient”.
Alas, with conventional automobile piston engines, efficiency is loud. Take off the muffler, get noise, more efficiency, and more power. Replace the exhaust manifold with tuned headers, same result. A few watts of acoustic energy is very loud, and vanishes in comparison to hundreds of kilowatts of engine power.
You’re confusing efforts to mask those efficiency losses with the sources of those efficiency losses.
What maxzillian said. Noise from a motor is efficiency loss, the same way heat is efficiency loss in lighting. Muffling that inefficiency only creates even more inefficiency.
A single rotor helicopter needs a more complicated mechanical system for cyclic control, this makes it work with only collective control. Nice hack, could have potential.
The quadcopter format is great at making small, cheap, maneuverable toy RC aircraft.
When you want efficiency and load carrying at this kind of scale, traditional helicopters are better in nearly every way.
Even traditional RC helicopters, which are available with a wide variety of power plants and sizes, and have had variable pitch hardware in some configurations for many decades, just like their fixed wing counterparts.
I’m surprised there are still so many attempts to reinvent every aspect of aviation, but I guess I shouldn’t be as the average DIY drone project is not by an aviator, and aviation specialists have had bigger fish to fry.
Reminds me of the Stingray 500 from 2013. It was a single motor quad that used a belt drive for all four rotors and variable pitch for control. It let pilots play with endurance numbers a bit because they could set an upper limit on the RPMs and just play with pitch for normal flight.
Its nimble enough aerobatics and fast enough for racing… and I never heard anything after it initially debuted. Always wanted to see if it could be scaled up to see if I could make a manned version.
https://www.youtube.com/watch?v=TnGhEInTXYc
And of course I read the article, reply, then watch the video only to see him mention the Stingray at 2:40.
I have one. It mostly flew as advertised, and was almost as aerobatic as single-rotor RC helicopters. The biggest drawback was that yaw control was rather weak.
Fun fact: the rotors are just repurposed tail-rotor mechanisms from conventional RC helicopters.
I expected that repurposing after looking over a friend’s then contemporary helicopter, but never actually knew, makes sense now just as then.
I had an attempt at this concept around that time. I was inspired by the Stingray. My relatively low budget caused some fundamental design flaws but I did manage to get it off the ground.
I used knockoff Trex250 helicopter tails with directly attached brushless motors. The cheapo motors and ESCs didn’t run well at low speeds. Too much pitch would bog down the motors and mess with the PIDs.
I concluded that a single-motor synchronised drivetrain would be much more stable.
https://youtu.be/sfEV7EobLZg?si=CCIZuawEWD_TFhfE
Maybe he should try flaps instead of changing the pitch of the whole blade… To get a more granular control
