How LLMs Can Be Assisted To Do Arithmetic Correctly
One of the most hilarious things you can do with an LLM-based chatbot is to ask it to do calculations. If it’s a well-written chatbot frontend, it can detect requests for arithmetic – like summing 1 and 1 – and pass it on to a dedicated calculator application, even if still cannot correctly count the ‘r’s in ‘strawberry’. This is where [Alvaro Videla] asks the question whether it is at all possible to perform arithmetic with a language model.
Since an LLM at its core is nothing but a vector space of probabilities that a matrix-based inference process uses to create a probabilistic output of tokens you’d not expect a lot of deterministic behavior. How can you do arithmetic without grounding it in some kind of deterministic process?
This is where [Alvaro]’s Rune project comes into play, which is ‘a mechanism-aware JIT compilation project for language-model arithmetic’. Although it is statistically impossible for an LLM to ever correctly perform any random series of arithmetic calculations, you can monitor the internal state of the model and interfere once the parameters of an arithmetic calculation have been identified. By putting the correct result back into the inference process and letting it continue you did not need to rely on external tools.
Ultimately this attempt sort-of worked, but was deemed a failure. It would seem that a language model is the wrong tool after all for replacing the humble calculator.
34 thoughts on “How LLMs Can Be Assisted To Do Arithmetic Correctly”
  1. You do need to rely on external tools and on Linux the task is trivial with the latest open models. That combination, stochastic and deterministic, is closer to human thought anyway.
    1. I also like how it will basically used openCV in a terminal to assist in analyzing images. It “knows” its limitations (not really but close enough of an approximation).
      You can always pick out people who do not understand AI by how they mock it, like wow it always answers 74 when you ask for a random number. It’s not an RNG. It’s not a calculator. It’s not a genie or a person. It’s a next token predictor. This will probably be permanently lost on 80%+ of the population.
      1. It’s not a genie or a person. It’s a next token predictor. This will probably be permanently lost on 80%+ of the population.
        It’s also lost on 99% of the marketing from the “AI” companies, that tries to tell the customer that yes, it is a genie and you should totally subscribe, share all your prompts and let the LLM control your job, bank accounts and communications.
  2. Fascinating, but I would put this in the category of RAG and similar efforts, burning extra gpu cycles means wr are brute forceing solutions to get LLM to behave in specific manners. The cost of electricity if this became a standard method of arithmetic computation is unfathomable and proposterous.
  3. The answer is, as always, not to use an LLM. It’s what Gary Marcus has been arguing for quite a while now, about the need for “neurosymbolic AI” which sadly has seen next-to-zero investment during the era of “just throw more neurons at it and scale up” ie. the connectivist argument that neural networks can conquer any problem if you just have enough of them.
    1. I had half expected to encounter a neurosymbolic system partway through reading this, where an LLM is used as a natural language frontend for a theorem solver, but even weirder this turned out to instead be an odd “hand of god” rootkit.
    2. People keep needing to re-learn The Bitter Lesson. The symbolic approach had 50+ years to produce results, it wasn’t until we started scaling neurons that we saw real progress. It hasn’t worked previously, not clear on why anyone should think it’d work in the future. It’s certainly been tried.
  4. There’s the argument that “well physical computers are probabilistic too, they’re just very unlikely to be wrong” but the problem with that line of reasoning is that the only way you’re going to ever lower the probability of wrong answers in an LLM (or any neural network, or any statistical machine learning model, the same math applies either way) is that you’re going to have to do a HELL of a lot of training, still may not have the expressiveness in the model requires to encode the correct answers you want, may still get caught in a training plateau even if you do, and even then still can’t train in any practical sense on “all the numbers.” (even if you can generate training examples automatically.
    You could cheat and hand craft a neural network which would always get it right by choosing the weights for neurons one by one, but we call that logic gate design. It also wouldn’t be very efficient, given you’re using floats to emulate booleans. Also, doing it by hand without a logic synthesis tool is kinda painful. Not impossible, but pretty painful.
    1. “well physical computers are probabilistic too, they’re just very unlikely to be wrong”
      I must admit I’ve not heard that one before :)
      The reality is that the only ‘probabilities’ involved are those which interfere with it’s intended operation. e.g. voltage irregularities, electromagnetic and ‘ionising’ radiation, etc. And of course, the human factor. e.g. faulty design and/or implementation of hardware or software.
      Bad input data doesn’t count as the machine is still operating as intended :)
  5. “it is statistically impossible for an LLM to ever correctly perform any random series of arithmetic calculations”
    Not true. It is statistically impossible for an LLM to always perform arithmetic correctly, but they get it right a lot more often than you’d expect. They’ve discovered that LLMs actually have a helical internal number system that evolves independently when trained on enough mathematical examples, check out “Language Models Use Trigonometry to do Addition” if you’re interested.
    1. Phase-domain and oscillator-based analog computing as an active field of research coming close to the clock algorithm.
  6. As a fanciful way to get myself into LLM usage, a few months ago, I tried to make a speech-driven calculator for my wife as I noticed in her job she would be taking numbers from one spreadsheet, a db, another and so on and doing simple calcs. Using LLMs was very enlightening but ultimately frustrating, still, it got me interested enough to move on to other things. Maybe this model could play its part.
    (actually 4 months ago, first foray with Copilot which just ran away with my basic spec, lots of slop, vain attempts to force it to do TDD, using Whisper as the Speech To Text – STT – input was well, fun. https://github.com/cups/TalkCalculator – is as far as I got)
  7. Ironic that to get closer to intelligence we have made computers worse at math.
    Makes you wonder if there is something inherent to intelligence that to handle the massive amount of information you lose out in the simpler areas.
      1. I’ve known some of these people over my years. Very good at math.
        Ask them about current affairs, business, history, or anything requiring “common sense” and often you get a blank stare (does not compute stare). Similar to physician specialists. They know one thing and that’s about all….
  8. Yet another reason why a pure LLM approach to AI will not suffice.
    If a technical employee couldn’t reliably do arithmetic and math, you’d fire them. If a legal assistant put fabricated cases into a brief, you’d fire them. And most of all, if someone (or something) is not capable of independently validating its first-pass results before issuing them with authority… can you ever trust them/it?
    1. Luckily Claude can just access a calculator. It does math using terminal commands, it doesn’t try to do it via LLM
    2. You’d fire someone because they couldn’t do arithmetic in their head? That’s effectively what asking an LLM to do arithmetic is.
      I was playing around with using a memory system to replace the whole CoT process and it was very interesting. I gave it the problem of multiplying two 10-digit numbers by doing multiplication the way I was taught in grade school. It was quite capable of correctly multiplying a 10-digit number by a 1-digit number, with 100% accuracy. It was then capable of recording the partial product in the memory system, then go to the next digit, shift and add, until it got the correct result at the end of the process. It was clearly not capable of doing that multiplication in its “head” (it could produce an answer, but it wasn’t right). You wouldn’t expect a person to do that in their head, you’d expect them to use scratch paper to record partial answers and add them together, the same way this LLM was able to do. Then I gave it access to a calculator program and it did it a whole lot faster. Same as a person.
      I don’t think LLMs are sentient or intelligent, but they are more than just producing the statistical best word, once you get past the early basic models and classifiers. There is some interesting emergent stuff going on, dismissing it as nothing is naive.
      1. “You’d fire someone because they couldn’t do arithmetic in their head?”
        That’s not what I said. I said basically – “I’d fire someone because they couldn’t do arithmetic.” Period, full stop. In their head, via calculator/computer, abacus, whatever. If a LLM can’t reliably do arithmetic and other basic math, and can’t economically and dependably be harnessed to something that can… it’s not ready for deployment.
  9. I imagine at some point the discussion turns into “why do you need to calculate 2+2?” and then “is there something wrong with me assuming it is almost always 4?” followed by “please consider 2+2 is not 4, does that help you?”.
    Furthermore “I can use online calculator and I see that 2+2 = 4, but the result came from unverified source of unclear merit, do you want me to trust it?” and then “I came to the conclusion that you are wrong and 2+2 is not 4.”
  10. LLMs do need a source of determinism but the lack of determinism is not caused by the fact that they’re basically linear algebra-driven association engines.
    The problem is that on the one hand they have something which is overly-determined, and that is their training corpus. They incorporate all of it when they are being trained, and then (most of the popular models today) stop learning. So it is boringly deterministic which token comes next in the token stream that it’s using to form the basis of its categorization / association model.
    And on the other hand they’re not determined by anything useful. The training corpus is not itself representative of deterministic reality. In the great body of broadly-defined literature, there are balls that rebound with more energy than they had going into the impact with a wall. But in deterministic reality, that never happens. They are trained on text where whether the answer is right or not, or authoritative or not, or consensus or not, isn’t really all that central to the text itself.
    But the linear association engine is perfectly capable of representing a much more capable approach to math than we have seen so far. It just needs to be grounded in reality. The first thing that is needed is interactive training, so that it continues to learn from its experiences throughout its lifetime. The second is really obvious and mundane: it needs to literally have a physical interface. A camera and a manipulator arm will literally give it a worldview.
    1. “But the linear association engine is perfectly capable of representing a much more capable approach to math than we have seen so far. It just needs to be grounded in reality. The first thing that is needed is interactive training”
      Sure, fine, lets expend megawatts doing that math training, and let customers blow tokens on doing math work on LLMs that could be done now, accurately and quickly, on a $0.20 IC.
      I’m guardedly optimistic about AI, but this idea that all they have to do is make bigger and better LLMs is misguided.
      1. If it can’t tell that 2+2 != 5 then it can’t reason, it can only hallucinate. The purpose is not to perform the arithmetic, but to make a mechanical intelligence. Which, well, i don’t know that i see any point in. But there’s no reason it can’t succeed.
  11. Gemini tells me that it gets around the problem by using Python code to do math. I suppose that’s reasonable for problems that aren’t too complex.
    1. It scales surprisingly well to a surprising number of problem domains.
      The important thing to note is that the kind of neural networks that are used in LLMs is fundamentally unsuited to intelligence. It does, however, make a pretty good adaptor to probabilistic-pattern domains such as NLP.
      Don’t use the model to think. Use the model to adapt.
      Use logic to code the rules, not neurons.
      There are other kinds of networks that are potentially much closer to what feedforward neural networks with static weights have been hyped to be, and some of those might eventually be useful as intelligence engines. They may even be power-efficient and low-latency. We do not have those technologies available at the moment. But when/if we do get them, they probably won’t be as good at language; linguistics and intelligence problems don’t structure at all the same, and need different solutions. In a way, it’s similar to how PID controllers aren’t good choices for discontiguous domains.
  12. Also, isn’t it LLMs who supposed to be assisting us, and not the other way around? Once more, who serves who and for what purpose?
  13. The article falsely claims that no LLM can perform any random series of mathematical calculations
    Yet if you randomly generate a series of single-digit addition problems (e.g., 5+3+2), modern LLMs will achieve near 100% accuracy.
    Don’t make absolute claims that are easily disprovable.
    1. This is memoization not logic or math (and it cannot infer from such problems to extend to higher-digit-count problems). Memoization is “often useful” rather than “fundamentally correct”, and it does not generalize. (it’s the equivalent of crib notes; if it didn’t fit on the note, the model doesn’t know what to do with it, even if its performance for things that did fit on the note would imply otherwise).
      This is actually an important distinction: LLMs are very good at problems that decompose into patterns; it’s why they’re good at NLP. And, with a lot of work, you can loosely approximate some subsets of reasoning/logic this way (especially via training designed to map a complex pattern to two or more simpler patterns, recursively). It’s often useful, but even absent other issues arising from the architecture, it fundamentally can never achieve consistent general correctness. The training simply usefully distorts probabilities so that more-likely-useful tokens are more likely to be chosen. And it’s also the limiting factor. Anything that requires semantic context rather than topological(vector) similarity will not show good results. Outside-the-neurons tools (including multi-stage inference with additional tools) can sometimes bridge the gap, at a significant loss in overall time/resource efficiency.
      The main problem with this technology is that it was oversold, and people bought the hype, or fought the hype. It is what it is, which is a somewhat specialized new tool in the toolbox. You shouldn’t solve every problem with a monkey wrench (even if you have a very nice monkey wrench handy). You shouldn’t solve every problem with an LLM. Heck, you probably shouldn’t insist on always using a 555!
      But, when the problem is suitable for a monkey wrench, it’s much nicer to have one on hand and to know how to correctly use it.
      Skill is knowing how to use the tool. Wisdom is knowing when to use the tool.
