Every Type Of Current Sensor Explained
Measuring electric currents is an essential element of many electrical systems, but doing so in a way that is as nonintrusive as possible is not an easy problem to solve. Due to this we got a wide variety of current sensors to choose from for any given application, with [ElectrArc240] running us through these variants in a recent video.
The fairly low-tech, cheap and quite reliable method of using a shunt resistor is first demonstrated. This sees a lot of use in fairly low-voltage and low-current applications, with for example videocards using it to limit the amount of power the GPU can use, a feature that modders will happily bypass. Here simply the voltage drop across a known resistance value is measured, from which the current can be derived.
Of course, you got higher voltage and higher current applications too, as well as direct- and alternating current, with the latter especially allowing for easy current measurements simply from the electromagnetic field, or flux. Anyone who has used a clamp meter can attest to that such contact-free current sensing works, even for DC applications.
Beyond the basic transformer type you got many variants including Hall-Effect, TMR and fluxgate sensors, as well as the fiber-optic current sensor that uses an interferometer to measure the phase-change induced by the magnetic field – the Faraday effect – to the transmitted electromagnetic radiation. These more exotic types will improve resolution, at the cost of a rapidly increasing void in your project budget.
These various sensor types and their construction are demonstrated and discussed in the video, including when you’d want to use a specific type, and what the potential gotchas are with each type. Even if for many applications a simple shunt resistor suffices, it’s a good idea to know these different types, as well as their underlying theory of operation.
7 thoughts on “Every Type Of Current Sensor Explained”
  1. Just watched the video on youtube. It is definetely a master class in current sensors. So many types are presented further here that further reading up is required for any specific sensor that you find interesting.
  2. Amazing. This is the kind of stuff I like to see. From the most basic shunt techniques we use every day to the absolute crazy wizardry of measuring light polarization changes caused by current flow in an optical fiber.
  3. He didn’t mention one clever current probe for PCB traces. It has four contacts in a row and an active current source. The current flows between the outer two contacts and the included circuit servos that to end up with no voltage between the inner two. In other words, a Kelvin connected shunt with a closed loop, using the PCB trace as the shunt resistor.
