Hackaday editors Mike Szczys and Elliot Williams navigate the crowded streets of the hackersphere for the most interesting hardware projects seen in the past week. Forget flip-dot displays, you need to build yourself a sequin display that uses a robot finger and sequin-covered fabric to send a message. You can do a lot (and learn a lot) with a 1-bit computer called the WDR-1. It’s never been easier to turn a USB port into an embedded systems dev kit by using these FTDI and Bluepill tricks. And there’s a Soyuz hardware teardown you don’t want to miss.
Take a look at the links below if you want to follow along, and as always tell us what you think about this episode in the comments!
Take a look at the links below if you want to follow along, and as always, tell us what you think about this episode in the comments!
Direct download (60 MB or so.)
