NVIDIA Drops Pascal Support On Linux, Causing Chaos On Arch Linux
It’s no surprise that NVIDIA is gradually dropping support for older videocards, with the Pascal (GTX 10xx) GPUs most recently getting axed. What’s more surprising is the terrible way that this is being handled by certain Linux distributions, with Arch Linux currently a prime example.
On these systems, updating the OS with a Pascal, Maxwell or similarly unsupported GPU will result in the new driver failing to load and thus the user getting kicked back to the CLI to try and sort things back out there. This issue is summarized by [Brodie Robertson] in a recent video.
Here the ‘solution’ is to switch to a legacy option that comes from the Arch User Repository (AUR), which feels somewhat sketchy. Worse is that using this legacy option breaks Steam as it relies on official NVIDIA dependencies, which requires an additional series of hacks to hopefully restore this functionality. Fortunately the Arch Wiki provides a starting point on what to do.
It’s also worth noting that this legacy driver on the AUR is being maintained by [ventureo] of the CachyOS project, whose efforts are the sole reason why these older NVIDIA cards are still supported at all on Linux with the official drivers. While there’s also the Nouveau driver, this is effectively a reverse-engineering project with all of the problems that come with such an effort, even if it may be ‘good enough’ for older GPUs.
Continue reading “NVIDIA Drops Pascal Support On Linux, Causing Chaos On Arch Linux”
Delightfully Horrible Idea: Twitch Installs Linux
Linux is a delightful OS. There are an amazing range of built-in tools, and innumerable others that can be installed from publicly available repositories using just a single line of commands. You can also hose your entire system with just a handful of characters; something that was en vogue as a method of trolling many years ago. Who knows if either of those will get used when Twitch Installs Arch Linux.
Beginning on Saturday morning, a single keyboard will be controlled by thousands of people whose collective goal is to install a Linux distro in a virtual box. There will undoubtedly be thousands of others trying to thwart the process. We were enthralled with Twitch Plays Pokemon last year. Live viewers’ keystrokes were translated to the Game Boy controls and the majority consensus decided the next move. This was insane with just a few controls, but now we’re talking about an entire keyboard.
Every 10 seconds, the most popular keystroke will be chosen. To put this in perspective, the previous sentence would have taken exactly 10 minutes to type, and only if the majority constantly agreed on what the next letter should be. We can’t tell if it’s going to be interesting or boring to participate. But either way, we can’t wait to see what unforeseen happenings shake out of the process.
Cheap ARM Netbooks Have Linux Forced Upon Them
[Doragasu] got his hands on one of these WM8650 Netbooks for around 50 euros (~$63.50) delivered. They come with a version of Android preinstalled, but he wanted to use them more like a computer and less like an Android device. So he set out to load Arch Linux on the ARM-based Netbook.
This is possible because the hardware inside is actually pretty good. The 800 MHz SoC is accompanied by 256 megs of RAM. There’s 2 gigs of internal storage, a 7″ display, USB, Ethernet, WiFi, and an audio system. This is comparable to what you’d get with a Raspberry Pi (without video acceleration) but also includes all of those peripherals, a case, a touchpad and keyboard… you get the point. There are several patches that need to be applied to the kernel to get it working with the hardware. [Doragasu] covers each of them in the post linked above. You can also hear his presentation in the video after the break.
Continue reading “Cheap ARM Netbooks Have Linux Forced Upon Them”
