While electric vehicles (EVs) are generally less likely to catch fire than their internal combustion counterparts, it does still happen, and firefighters need to be ready. Accordingly, the UL Research Institute is working with reverse engineering experts Munro & Associates to characterize EV fires and find the best way to fight them.
There is currently some debate in the firefighting community over whether it’s better to try to put an EV battery fire out with water or to just let it burn. Research like this means the decision doesn’t have to fall on only anecdotal evidence. Anyone who’s worked in a lab will recognize the mix of exceedingly expensive equipment next to the borderline sketchy rigged up hacks on display, in this case the super nice thermal imagers and a “turkey burner on steroids.” The video goes through some discussion of the previous results with a Chevy Bolt, Hyundai Kona, Ford Mustang Mach E, and then we get to see them light up a Tesla Model 3. This is definitely one you shouldn’t try at home!
While the massive battery banks in modern EVs can pose unique challenges in the event of an accident, that doesn’t mean they can’t be repurposed to backup your own home.
Continue reading “UL Investigates The Best Way To Fight EV Fires”
