bikes are shown raised from the floor from the garage opener lift
Raise Bikes To The Heavens With Humble Garage Door Opener
Biking can be an incredibly rewarding hobby, but what do you do with all of your expensive pieces of metal and composite when you aren’t hitting the trails? They take up space that you could use for more bikes! [Chaz] figured there had to be a better way and discovered the unlikely solution of the humble garage opener.
Garage doors are made to lift high with moderate weight, exactly what one would expect from a bike lift. If you have high ceilings in your garage or wherever else you store your bikes there can’t be much easier than pushing a button to get your bike out of the way.
To assemble the unusual bike rack, [Chaz] mounted the motor to the wall with a few scraps of wood, and built a wooden platform that rides along the rail. This additional board allows you to use a traditional bike wheel rack to gently raise the bike. While initially [Chaz] had some questionable results, this was quickly resolved with removing the rotational elements of the mount and allowing a slight slant in the bike.
While not everyone may need to raise their bikes to the heavens, this type of simple hacking is always rewarding to see come together. If you want to see how some more bike specific tech works, check out the insides of this expensive bike seat!
Continue reading “Raise Bikes To The Heavens With Humble Garage Door Opener”
DIY Ceiling Rack Keeps Your Bikes Out Of The Way
bikke lift
Need to optimize some space in your garage? Why not build a ceiling mounted winch-assisted bicycle rack!
[Mathieu] already has a rather spacious garage, but wanted to make it even more organized. He built the bicycle rack out of 1″ square aluminum tubing, and it’s all bolted together (no welding required!). The bikes sit in aluminum U-channels to be secured in place. The entire rack is hinged off of the back wall, and a pulley system using a little ATV winch raises and lowers the rack for easy access to the bikes.
It’s currently powered off a 12V motorcycle battery, which he plans to add a trickle charger to — that being said, it has lasted for more than 6 months and he still hasn’t had to recharge it! He threw together a little control circuit featuring two relays (up and down) and a 2 channel remote control. The motor is a little slow, but it does the job quite well. If he wanted to get it going a bit faster, he could probably double the voltage to allow for a quicker movement — since it’s only on for short periods of time it should be okay. Seeing hacks like this has us wondering just how many winch-driven extras you could build into a single abode.
Check out the following video of it in action!
Continue reading “DIY Ceiling Rack Keeps Your Bikes Out Of The Way”
Putting A Workshop On Your Bike Rack
As a member of the Repair Cafe in Maastricht, [Bertoa] sometimes needs to take a few tools out into the field to repair mechanical and electronic devices. His previous solution to the problem was a toolbox in the trunk of his car, but he knew he could come up with a more environmentally friendly solution. He created a portable workbench that fits right on his bike rack that is able to transport all the tools needed for light repairs using only a bike.
[Bertoa]’s portable workbench is made up of two parts; each side has one small slide drawer perfect for storing screwdrivers and wrenches, as well as a second tilting drawer able to hold heavier items such as an electric drill.
The work surface joins the two sides of the workbench together and is able to fold out with the help of a piano hinge and a few brackets. The workbench is removable from the bike rack and is able to stand on its own (stowable) legs made of aluminum tubes.
Even though the portable workbench only weighs about 10kg, it’s able to support [Bertoa]’s full body weight; a wonderful addition to any maker’s bicycle and a great solution to working on projects in the field.
Hackaday Links: August 3, 2012
Oh cool we’re famous
Last weekend, the Tech Team Radio Show over in Stoke-on-Trent interviewed our boss man [Caleb]. It’s a really wonderful interview, and I’m not saying that because [Caleb] signs my check. The entire show is up on Mixcloud and you can listen to the interview beginning at about 20 minutes. By the way, the guy who interviewed [Caleb] is now writing for us. Please welcome [Richard] to our motley crew.
Group buys are an awesome idea
We’ve seen Tindie, an Etsy for your electronics projects, a few times before. [emile] put up a blog post showing the impressive stats for the first month: $646 went to makers and nearly 29,000 unique pageviews. [emile] is working on a new project called Starter. This feature allows makers to gauge interest in their project and organize group buys for rare and esoteric components. We can’t wait to see this feature go live, and of course we’ll plug it when it does.
First Tindie, now fixie
[Adam] needed a way to store his bike, so he made a swinging wall mount for his fixie. The mount is bolted to a door frame and since it swings it’s never in the way.
The latest advances in blanket technology
During the opening ceremony for the Olympics, [schobi] saw some really cool light-up blankets. From this picture it really looks like these blankets are emitting light, but we have no idea how this was done. Does anyone have an idea on how this effect was produced?
coughRaspberryPicough
[Craig] needed a way to mount PCBs that didn’t have any mounting holes. He came up with a laser cut Delrin clip and put the file up on Thingiverse.
