Using A Thermal Camera To Spot A Broken Wrist
Chemist and Biochemist [Thunderf00t] has shown us a really interesting video in which you can spot the wrist he broke 10 years ago using a thermal camera.
He was on an exercise bike while filming himself on a high-resolution thermal camera, As his body started to heat up he noticed that one hand was not dumping as much heat as the other. In fact one was dumping very little heat. Being a man of science he knew there must be some explanation for this. He eventually came to the conclusion that during a nasty wrist breaking incident about 10 years ago it must have affected the blood-flow to that hand, Which would go on to produce these type of results on a thermal camera while exercising.
Using thermal camera’s to spot fractures in the extremities is nothing new as it has the benefit of eliminating radiation exposure for patients, But it’s not as detailed as an X-ray or as cool as fluoroscopy and is only useful for bones near the surface of the skin.  It’s still great that you can visualize this for yourself and even after 10 years still notice a significant difference.
Continue reading “Using A Thermal Camera To Spot A Broken Wrist” →
New Shape-Shifting Polymer Works Hard, Plays Hard
A research group at the University of Rochester has developed a new polymer with some amazing traits. It can be stretched or manipulated into new shapes, and it will hold that shape until heat is applied. Shape-shifting polymers like this already exist, but this one is special: it can go back to its original shape when triggered by the heat of a human body. Oh, and it can also lift objects up to 1000 times its mass.
The group’s leader, chemical engineering professor [Mitch Anthamatten], is excited by the possibilities of this creation. When the material is stretched, strain is induced which deforms the chains and triggers crystallization. This crystallization is what makes it retain the new shape. Once heat is applied, the crystals are broken and the polymer returns to its original shape. These properties imply several biomedical applications like sutures and artificial skin. It could also be used for tailored-fit clothing or wearable technology.
The shape-shifting process creates elastic energy in the polymer, which means that it can do work while it springs back to normal. Careful application of molecular linkers made it possible for the group to dial in the so-called melting point at which the crystallization begins to break down. [Anthamatten] explains the special attributes of the material in one of the videos after the break. Another video shows examples of some of the work-related applications for the polymer—a stretched out strand can pull a toy truck up an incline or crush a dried seed pod.
Continue reading “New Shape-Shifting Polymer Works Hard, Plays Hard” →
