[Stephen] doesn’t have the luxury of readily available hot water in his apartment, and since he’s just renting he didn’t want to buy one of those instant powered units, so he decided to go ahead and build his own!
He’s using a submersible 1000W immersion heater in a 2.5 gallon water container which has been mounted high up in his bathroom to let gravity do the work for actual shower. It’s not quite an instant shower unit as the water needs to heat up like a kettle before being used — this takes about 4 minutes to hit the optimum temperature.
The current shower head installed drains the tank in about 2.5 minutes, which might not seem like much time for a shower, but let’s be honest — we could all probably cut back our shower time and save some water for the environment! Something one of our Hack a Day Prize entries is hoping to solve through music!
Continue reading “Homemade Hot Water Shower Might Shock You”
