When id Software released DOOM back in 1993 it helped define the genre, but it was hardly the only hit first-person shooter of that decade. There was also 3D Realms’ 1996 Duke Nukem 3D, a game which added some humor to the genre. Here’s [PicoPlus-devel], with pico-duke3D. It’s Duke Nukem 3D, on an RP2350.
Before reaching the conclusion that this might be obvious and easy, the three years between the two releases saw quite significant movements in the world of gaming PCs. DOOM’s minimum spec in 1993 was a 386 and 4 MB of memory, and would have been playable on a basic VGA card in an ISA slot. By contrast three years later Duke Nukem 3D required at least a 486DX2 and 8 MB, which would inevitably have had VESA local bus or PCI graphics. It’s a Quake competitor rather than a DOOM competitor, thus the power required to run it has stepped up a notch or two.
The RP2350 then is up to the job, and runs the game on a DVI equipped Pico clone. It can be controlled via either SNES or USB controllers given the right hardware, making it the perfect one-game console. The shareware game works, as does the full version if you own a copy. Having been around in the ’90s then, we’re curious. Could it be made to run Shadow Warrior as well? You no mess with Lo Wang!
