A tired 1990 Chevy Lumina isn’t the platform one would normally pick for a custom build. When you’re drag boat racing team on a budget though, you use what you can get cheap. Normally small boats are launched and landed using a trailer and tow vehicle. [Ashley Ruf’s] team at Little John’s racing is launching her boat “Kwitchabitchin” with a bit more style.
The team started by cutting the Lumina in half. Since the Chevy is a front wheel drive platform, everything behind the driver is more or less along for the ride. The gas tank was relocated, and notched to receive the front of the boat. The team then added a quad tire trailer frame. The frame is connected to the car with a long hydraulic cylinder. When the boat is being launched or landed, the cylinder can extend far enough to get the boat floating.
You might be thinking that there is no way this is street legal, and you’d be right. The Lumina only gets the boat into and out of the water. The boat is then pulled all the way forward using the hydraulics. The boat/car pair is a then perfect fit inside the team’s racing travel trailer.
You can check out a video of the car at work after the break
