The EVIC is a computer controlled internal combustion engine, utilizing a cam less solenoid actuated valve system. In addition to intake and exhaust valve control, the processor also handles ignition timing. With dynamic valve timing, it is possible to make an engine more efficient. Where a classic combustion engine would wastefully burn fuel, the EVIC can skip power cycles which are not needed. By increasing the valve duration, the CPU enables easy starting. The latest is the EVIC Mk3 which adds an exhaust valve sensor, and 3:1 solenoid leverage. There is a photo gallery with several EVIC engines. The Mk2 Twin is demonstrated in the video embedded below.
