Art of 3D printer in the middle of printing a Hackaday Jolly Wrencher logo
Improving FDM Filament Drying With A Spot Of Vacuum
Keeping your filament safely away from moisture exposure is one of the most crucial aspects of getting a good 3D print, with equipment like a filament dryer a standard piece of equipment to help drive accumulated moisture out of filament prior to printing or storage. Generally such filament dryers use hot air to accomplish this task over the course of a few hours, but this is not very efficient for a number of reasons. Increasing the vaporization rate of water without significantly more power use should namely be quite straightforward.
The key here is the vapor pressure of a liquid, specifically the point at which it begins to transition between its liquid and gaseous phases, also known as the boiling point. This point is defined by both temperature and atmospheric pressure, with either factor being adjustable. In a pressure cooker this principle is for example used to increase the boiling temperature of water, while for our drying purposes we can instead reduce the pressure in order to lower the boiling point.
Although a lower pressure is naturally more effective, we can investigate the best balance between convenience and effectiveness.
Continue reading “Improving FDM Filament Drying With A Spot Of Vacuum”
A man in a red plaid shirt draped over an olive t-shirt holds sandpaper in one hand an an aluminum tube filled with white beads in the other over a wooden table.
Activated Alumina For Desiccating Your Filament
When you first unwrap a shiny new roll of filament for your FDM printer, it typically has a bag of silica gel inside. While great for keeping costs low on the manufacturing side, is silica gel the best solution to keep your filament dry at home?
Frustrated with the consumable nature and fussy handling of silica gel beads, [Build It Make It] sought a more permanent way to keep his filament dry. Already familiar with activated alumina beads, he crafted a desiccant cylinder that can be popped into the oven all at once instead of all that tedious mucking about with emptying and refilling plastic capsules.
A length of aluminum intake pipe, some high temperature epoxy, and aluminum mesh are all combined to make a simple, sealed cylinder. During the process, he found that using a syringe filled with the epoxy led to a much more precise application to the aluminum cylinder, so he recommends starting out that way if you make these for yourself.
We suspect something with a less permanent attachment at one end would let you periodically swap out the beads if you wanted to try this hack with the silica beads you already had. Perhaps some kind of threaded pipe fitting? If you want a more active dryer, try making one with a Peltier. If you want to know just how dry your filament is getting, you could also put in a sensor. You might also wonder, do you really need to dry filament at all?
Continue reading “Activated Alumina For Desiccating Your Filament”
Slow Cooking Filament
Getting good results from a 3D printer is like Goldilocks’ porridge. There are a lot of things that have to be just right. One common thing that gives people poor results is damp filament. This is especially insidious because the printer will work fine and then after some period time results degrade but it is no fault of the printer mechanics or electronics. There are many ways to attempt to dry filament, but [HydeTheJekyll] prefers using a slow cooker modified to operate with low air pressure.
We assume this works because the low pressure reduces the boiling point of water, allowing the water to boil off at temperatures that won’t distort the filament. The modifications aren’t very severe. You’ll need some hose and a pump along with some silicone caulk and petroleum jelly.
Continue reading “Slow Cooking Filament”
Budget Dehydrator Gives Your Damp Filament A Second Chance
If you’ve had the misfortune of leaving your 3D printer filament out on a muggy day or, heaven forbid: showering with it, it’s probably soaked up quite a bit of moisture. Moisture will do more than just make your printer sound like Rice Crispies, it’ll ruin surface finishes and cause the filament to string into thin wisps between separate geometries on the same layer. Luckily for us, though, both [SafetyGlassesRequired] and [Joe Mike Terranella] give us the breakdown on taking a pair of snippers and about $40 in cash to start drying out our filament far away from the possibility of ruining any nearby kitchen ovens.
If you’ve been circling the 3D printer community for a while, you might have already heard about this trick. But with the arrival of a curiously-culinary-looking contraption called PrintDry, we can’t let the elephant in the room keep silent for much longer. Rather than risk our own pennies and leave ourselves stranded with a device that only makes the jerky on the box cover, [SafetlyGlassesRequired] and [Joe Mike Terranella] kindly prove our suspicions for us once and for all: a food dehydrator works perfectly for drying all that filament that we left out in the rain!
Clumsiness aside, a dehydrator isn’t a bad investment in the long run. Not only can we keep our supply dry, we might just be able to give all that freebie filament (that we dug out of the trash) a second life by resetting it to a clean, dry state.
These dehyrdators will toast all that moisture out of your filament, but it wont keep them dry whilst printing. For that problem, you’ll need to summon a heated drybox like this one.
[Joe Mike’s] solution will run us about $40. If you can do better, let us know in the comments.
Continue reading “Budget Dehydrator Gives Your Damp Filament A Second Chance”
