We missed the original announcement, but Apple unveiled more than just the iPad Mini at their last event. They’ve got a new storage system called Fusion Drive which is supposed to combine the access speeds of solid state with the storage density of platter drives. When you look just under the surface what you’re really seeing is a disc drive with grossly enlarged cache in the form of an SSD drive. How about moving from the 64 MB or so of cache seen on many large hard drives today to something like 64GB?
Well you don’t have to wait for Apple to do it. [Patrick Stein] gave it a shot using command line tools to combine an SSD with a physical drive. Sure, it’s not an all-in-one solution, but it is a pretty good proof. The linchpin that will really make it possible is a low-level driver that can handle the caching on the SDD, while ensuring that the data eventually makes it to the platter for long-term storage.
[via Engadget]
