Hackaday editors Mike Szczys and Elliot Williams sort through the hacks you might have missed over the past seven days. In FPGA hacking news, there’s a ton of work being done on a newly discovered FPGA dev board. Kristina has a new column on input devices, kicking it off with tongue-actuated controllers. We wax philosophical about what data you need to backup and what you should let go. Plus Audacity is helping tune up CNC machines, copper tape is the prototyper’s friend, and fans of Open should take note of this laptop project.
Take a look at the links below if you want to follow along, and as always tell us what you think about this episode in the comments!
Take a look at the links below if you want to follow along, and as always, tell us what you think about this episode in the comments!
Direct download (60 MB or so.)
