Perhaps we’re not alone in having a penchant for gummy sweets, but we have to admit to never following the train of thought shared by [Lost Art Press]. Upon finding that a hide glue ingredient was raw gelatin obtained from a confectionery company, they stored away the knowledge and eventually tried making some glue using Haribo Goldbears from a gas station.
Melting the anthropomorphised sweets in a pot with a little water produced a thin glue, which was tried on a couple of bits of wood. The test joint duly stuck together, and after a few weeks for it to set it was time to test it. Simply hitting it with a hammer caused the wood to fracture, but using more traditional hide glue dissolving techniques with water or alcohol gave the expected result of parting it.
So a pretty usable hide glue for woodworking can be made using gummy sweets. We think it’s pretty cool, but perhaps given how easy it is to buy either the real thing or a PVA-based alternative, that this is one for the MacGyver file. Should you ever find yourself stranded in a gas station unable to save the world for want of a bit of glue then now you have the crucial bit of knowledge. Until then, leave out Haribo Goldbears alone!
Thanks [Aaron Tagliaboschi] for the tip!
