Does vibe coding risk destroying the Open Source ecosystem? According to a pre-print paper by a number of high-profile researchers, this might indeed be the case based on observed patterns and some modelling. Their warnings mostly center around the way that user interaction is pulled away from OSS projects, while also making starting a new OSS project significantly harder.
“Vibe coding” here is defined as software development that is assisted by an LLM-backed chatbot, where the developer asks the chatbot to effectively write the code for them. Arguably this turns the developer into more of a customer/client of the chatbot, with no requirement for the former to understand what the latter’s code does, just that what is generated does the thing that the chatbot was asked to create.
This also removes the typical more organic selection process of libraries and tooling, replacing it with whatever was most prevalent in the LLM’s training data. Even for popular projects visits to their website decrease as downloads and documentation are replaced by LLM chatbot interactions, reducing the possibility of promoting commercial plans, sponsorships, and community forums. Much of this is also reflected in the plummet in usage of community forums like Stack Overflow.
