Big Clive Hacks LED Bulbs With OpenSCAD
After accidentally crushing the plastic envelope on a cheap LED light bulb, [bigclivedotcom] figured out he could make custom ones using OpenSCAD in any shape he wants. He previously hacked a bunch of these inexpensive LED bulbs last month, discovering they all shared a similar circuit topology. All the ones he experimented with drove the LEDs hard, something that’s bound to reduce bulb lifetime. By reverse engineering the current control regulator, it turns out it is easy to adjust the drive current by changing a resistor or two. Reducing the current should not only increase lifetime, but could allow repurposing the bulb for other uses, such as decorative lighting.
Tweaking the LED Current
Three OpenSCAD scripts are provided which generate what he calls diamond, obelisk, and globe styles. Basic parameters for each style can be tweaked by the user, such as feature sizes and number of facets. He mentions the lack of OpenSCAD customizers in his script — this can easily be added as shown in the following example (this section of the User Manual on customizers explains the syntax). Note that you can’t make the slider generate real numbers, only whole numbers, which is why the scaling factor is multiplied by 10.
Adding Parameter Customization Sliders is Easy
These fancy globes can be used as night lights and possibly outdoor lighting, if you can make a good seal with the base. Custom chandeliers, anyone? Indicator lamps for very large panels? Any other ideas? If you want to explore the LED lifetime issue further, inveterate tinkerer Ted Yapo wrote a deep dive into the mythical 100,000 hour LED bulb. Thanks to [Cliff Claven] for the tip.
Continue reading “Big Clive Hacks LED Bulbs With OpenSCAD” →
World’s Most Expensive Industrial Pipe Cover
Crystal LED Structure
It’s not hard to get HaD’s attention when you cram 1000’s of RGB LEDs into a single project. In fact, this funky crystal pipe has over 9000 of them!
The rather unique project was privately commissioned to cover up an exposed pipe in a new building. It seems like a bit of overkill to us, but the engineers at Asylum were more than excited to deliver. The pipe covering features 2,912 control modules for the RGB LEDs and are controlled by a dedicated Linux PC built into the installment. A website was created to allow the client to control the lights from any computer or mobile device.
Each crystal shard was individually glued to the surface (there’s around 3000 of them!) using UV hardening glue. It was a painstakingly slow process, but well worth the result as it looks like it’s out of Superman’s Fortress of Solitude!
Continue reading “World’s Most Expensive Industrial Pipe Cover” →
