Backyard LED Sculpture Inspired By Las Vegas Sphere
The Las Vegas Sphere is a large building. It stands 112 meters high and 157 meters wide, and is covered in a full 54,000 square meters of LED displays. That’s a little difficult to recreate at home for the typical maker. A scaled-down version is altogether more achievable though, as demonstrated by [DrZzs & GrZzs].
The Pixelhead Megasphere, as it is known, is 1.98 meters high and 2.4 meters in diameter. That makes it altogether easier to fit in an average backyard, and it comes with a much smaller pricetag than the $2 billion used to build the Las Vegas Sphere. It runs 20,028 individual addressable LED pixels, and runs on four 12-volt 100-amp power supplies. As seen here, it’s only running at 15%, so it can go plenty brighter to really get those power supplies toasty. The sphere is controlled by Xlights, with the LEDs interfaced via Kulp controller boards. It’s able to run a variety of different animations at a good frame rate, with [DrZzs & GrZzs] busy whipping up different designs for Halloween. The eye of Sauron is a particularly nice example.
We’ve seen some other neat LED spheres before, too. Video after the break.
Continue reading “Backyard LED Sculpture Inspired By Las Vegas Sphere” →
194 LED Ball Is Free-Form Soldering On Another Level
We’ve all seen plenty of impressive free-form soldering in these pages, maybe some of us have even had a go ourselves. Using nothing but bare conductors, electronic components, and solder, complex and beautiful electronic sculptures can be created. But the latest free-form project from [Jiří Praus] takes the medium to a new level, as he’s taken no less than 194 bare surface-mount addressable LEDs and formed them into a perfect sphere supported by nothing more than soldered copper wire.
This feat was achieved with the aid of a 3D printed hemispherical jig with spaces for each LED, and each half was assembled in a marathon soldering session. Some significant fault-finding was required due to a few dry joints, and an ESP32 board and Li-Po cell were fitted in between the two halves as they were joined. The result is a triumph, a Christmas bauble like no other, and one which we aren’t sure we could manage to solder so well even on a good day.
If you recognise [Jiří ]’s work, it’s probably because we’ve featured several of his creations previously. It’s always difficult to pick a favorite, but the one which caught our eye the most was his fully functional freeform Arduino Uno.
Continue reading “194 LED Ball Is Free-Form Soldering On Another Level” →
