What can you build with a ballpoint pen and some extra parts? [gzip] found himself with a bonus box of right angle switches and other miscellaneous parts and set out to build a joystick. Simple arcade joysticks use switches that are actuated by the movement of the stick and this design embraces the concept. The four tactile switches are mounted on protoboard facing each other with part of a ballpoint pen in the middle. When the pen is moved it presses against one or more switches to close, completing a circuit. For good measure he even incorporated a fire button into the top of the “stick”. Now we just need someone to make this work with a tiny Ms. Pac-Man emulator.
