[Bill Dudley’s] wife wanted to use a couple of different tablets for displaying sheet music. Sure, a proper music stand will have no trouble supporting the weight of the device, but if it’s not secured it place you may soon have a broken device. [Bill’s] solution was to build this tablet stand out of PVC.
The image above doesn’t tell the entire story of how he did this. But if you look really closely you’ll notice that the pipe is actually acting as a frame rather than a cradle. After measuring, cutting, and gluing all of the components together he cut a channel around the inside of the u-shaped PVC frame. The channel is the exact thickness of the tablet and holds the device securely. A base from a music stand makes up the rest of the rig.
Pages can be turned using a USB foot pedal. This is fantastic for gigging musician who use digital music collections like the Real Book.
