Illustrated Kristina with an IBM Model M keyboard floating between her hands.
Keebin’ With Kristina: The One With The Protractor Keyboard
Don’t you love it when the title track is the first one on the album? I had to single out this adjustable keyboard called the Protractor, because look at it! The whole thing moves, you know. Go look at the gallery.
The Protractor, an adjustable monoblock split keyboard with sliding angles.
Image by [BFB_Workshop] via reddit
If you use a true split, even if you never leave the house, you know the pain of losing the good angle and/or separation you had going on for whatever reason. Not only does this monoblock split solve that simply by being a monoblock split, you can always find the right angle you had via the built-in angle finder.
[BFB_Workshop] used a nice!nano v2, but you could use any ZMK-supported board with the same dimensions. This 5 x 12 has 60 Gateron KS-33 switches, which it was made for, and has custom keycaps. You can, of course, see all the nice, neat ribbon cable wiring through the clear PLA, which is a really great touch.
This bad boy is flat enough that you can use the table as your palm rest. To me, that doesn’t sound so comfortable, but then again, I like key wells and such. I’d still love to try a Protractor, because it looks quite interesting to type on. If you want to build one, the files and instructions are available on Printables.
Continue reading “Keebin’ With Kristina: The One With The Protractor Keyboard” →
