Balancing A Turbine Rotor To 1 Milligram With A DIY Dynamic Balancer
Although jet engines are theoretically quite simple devices, in reality they tread a fine line between working as intended and vaporizing into a cloud of lethal shrapnel. The main reason for this is the high rotational speed of the rotors, with any imbalance due to poor manufacturing or damage leading to undesirable outcomes. It’s for this reason that [AlfMart CNC Garage] on YouTube decided to spend some quality time building a balancer for his DIY RC turbine project and making sure it can prevent such a disaster scenario.
In the previous part of the series the turbine disc was machined out of inconel alloy, as the part will be subjected to significant heat as well when operating. To make sure that the disc is perfectly balanced, a dynamic balancing machine is required. The design that was settled on after a few failed attempts uses an ADXL335 accelerometer and Hall sensor hooked up to an ESP32, which is said to measure imbalance down to ~1 mg at 4,000 RPM.
A big part of the dynamic balancing machine is the isolation of external vibrations using a bearing-supported free-floating structure. With that taken care of, this made measuring the vibrations caused by an imbalanced rotor much easier to distinguish. The ESP32 is here basically just to read out the sensors and output the waveforms to a connected PC via serial, with the real work being a slow and methodical data interpretation and balancing by hand.
Continue reading “Balancing A Turbine Rotor To 1 Milligram With A DIY Dynamic Balancer”
Running Methanol RC Engines On Gasoline
Methanol is a popular fuel for small engines used in radio-controlled models, but comes at a higher price than gasoline. It’s also harder to source and can be a mite corrosive, too. Gasoline comes with some benefits, but running it in a methanol engine usually requires some mods. [David] and [Bert] worked together to build a mixture controller for just this purpose.
The controller uses a solenoid to control the flow of gasoline to a conventional methanol-tuned carburetor for a small RC engine, allowing it to be accurately tuned to run gasoline well across the whole RPM range. Having gone through many revisions, all documented in a big forum thread, the latest version uses a Seeduino Xiao controller and a BMP280 pressure and temperature sensor for determining the right fuel/air mixture for the conditions. A small OLED screen can optionally be fitted to help with configuration of the mixture controller.
The system has worked well in testing, with [David] and [Bert] reporting that they have “converted engines as small as 0.3 CID up to large radials with this system.” It’s a promising tool that could be handy to have in the RC modeller’s arsenal.
These tiny engines have other applications too; they can make for one crazy power drill, that’s for sure!
Cordless Drill Uses No Electricity
There are few projects on how to make your own cordless drill, but what sets [Johnnyq90’s] amazing project apart is the fact that his power plant is a nitro engine. Not an easy task of course, but he makes it look easier than it is, and we really enjoyed the construction process.
He uses an RC Kyosho GX12 engine that was previously modified, changing the cooling head with a larger one. The engine drives a gearbox that was taken from another drill. All other parts were hand made. The clutch was carefully machined, and the cooling fan was made in a 3D printer. Other necessary parts were the frame, brass spacers to adjust the engine height and alignment, throttle arm and handle. In the end even the gearbox had to be modified for higher speed. The finished drill sure looks and sounds terrific, and seems to be perfectly capable of doing its job.
As with other mechanical projects from [Johnnyq90], the video has good timing and attention to detail. His channel is definitely worth a visit, specially if you like turbines.
