Illustrated Kristina with an IBM Model M keyboard floating between her hands.
Keebin’ With Kristina: The One With The Beginner’s Guide To Split Keyboards
Curious about split keyboards, but overwhelmed by the myriad options for every little thing? You should start with [thehaikuza]’s excellent Beginner’s Guide to Split Keyboards.
Three different split keyboards.
Image by [thehaikuza] via reddit
Your education begins with the why, so you can skip that if you must, but the visuals are a nice refresher on that front.
He then gets into the types of keyboards — you got your standard row-staggered rectangles that we all grew up on, column-staggered, and straight-up ortholinear, which no longer enjoy the popularity they once did.
At this point, the guide becomes a bit of a Choose Your Own Adventure story. If you want a split but don’t want to learn to change much if at all about your typing style, keep reading, because there are definitely options.
But if you’re ready to commit to typing correctly for the sake of ergonomics, you can skip the Alice and other baby ergo choices and get your membership to the light side. First are features — you must decide what you need to get various jobs done. Then you learn a bit about key map customization, including using a non-QWERTY layout. Finally, there’s the question of buying versus DIYing. All the choices are yours, so go for it!
Via reddit
Continue reading “Keebin’ With Kristina: The One With The Beginner’s Guide To Split Keyboards” →
