3D Print A Complete Wind Generator
For many of us our landscapes are dotted with wind turbines, the vast majority of which are horizontally aligned as if they were giant aircraft propellers. A much rarer sight is the vertical wind turbine, which remains a staple of the wind power experimenter. [Troy] and his brother have posted a video showing a small wind 3D printed vertical turbine, which unusually includes an alternator made from scratch as well as the rotor itself.
The machine adopts a Savonius rotor design with three scoops, which offers simplicity and high torque at a lower rotational speed than some of the alternatives. The scoops are assembled from a number of 3D-printed sections, and directly drive the generator which uses a large number of coils on a stator encircled by a rotor containing an array of magnets. A simple rectifier and three-terminal regulator produces a 5-volt output.
Sadly there was not enough wind to give it a decent test for the video, but they demonstrate it with a very large fan standing in. We like the alternator design but we’d be interested to see how the sectional rotors hold up in outdoor conditions, and perhaps that regulator could benefit from a switch-mode component. If you fancy a go he says he’ll release the files as open source if there’s enough interest. We’re interested [Troy], please do!
Many wind turbines have passed through these pages over the years, and for contrast here’s a horizontal 3D printed example.
Continue reading “3D Print A Complete Wind Generator” →
