[Imsolidstate] is working to add side turn signals to a trailer. These orange clearance lights are illuminated when the vehicle’s headlights are on to increase a long trailer’s visibility. They also blink along with the turn signals on the back of the trailer. A standard 6-pin lighting harness doesn’t support this functionality so the trick is to add them without altering the towing vehicle in any way. He’s using an ATtiny24 microprocessor to interpret the logic from the vehicle and then translate the turn signal and tail light data into a signal for the additional side indicators.
