Diamond Age-Inspired Pocket Watch Has ESP32 Inside
A lot of hacks get inspired by science fiction. When that inspiration is taken from the boob tube or the silver screen, the visual design is largely taken care of by the prop department. If, on the other hand, one seeks inspiration from the written word– like [Math Campbell] did for his smart pocket watch inspired by The Diamond Agethe visuals are much more up to the individual hacker. Though no nanotechnology was involved in its creation, we think [Math] nailed the Victorian High-Tech vibe of [Neal Stephenson]’s cult classic.
The build itself is fairly simple: [Math] started with a Waveshare dev board that got him the 1.75″ round touch display, along with an ESP32-S3 and niceties such as a six-axis IMU, an RTC, microphone, speaker, and micro SD card reader. That’s quite the pocket watch! The current firmware, which is available on GitHub, focuses on the obvious use case of a very stylish watch, as well as weather and tidal display. Aside from the dev board, [Math] needed only to supply a battery and a case.
[Math] designed the case for the watch himself in Fusion360 before sending it off to be 3D printed in stainless steel. That might not be molecular-scale manufacturing like in the book, but it’s still amazing you can just do that. Ironically, [Math] is a silversmith and will be recreating the final version of the watch case in sterling silver by hand. We’d be tempted to include a door–making it a “hunter’s case” in pocket watch lingo–to protect that amoled display, but far be it for us to tell an artist how to do his work. If you’re not a silversmith, [Math] has stated his intent to add STLs to the GitHub repo, though they aren’t yet present at time of writing.
We’ve featured smart pocket watches before, some with more modern aesthetics. Of course a watch doesn’t have to be smart to grace these pages.
Thanks to [Math Campbell] for the tip! If you’ve got time on your hands after ticking done on a project, send us a tip and watch for it to appear here.
It’s Time You Built A Smart Pocket Watch
There’s just something about a pocket watch that screams class compared to the barbaric act of bending your arm, or the no-fun way of looking at your phone.
But smartwatches are dumb, analog things that mostly look pretty. Or are they? [JGJMatt] proves otherwise with their stunning DIY smart pocket watch. It is essentially a cheap smart watch from Amazon stuffed into the shell of an old pocket watch, but you know it’s not quite that simple.
On the easier side of things, [JGJMatt] had to come up with a 3D-printed bracket to hold the smart watch’s guts. On the harder end of the spectrum, he ended up building the charging port into the crown, where the latch used to be.
This is a beautiful build for sure, and a great way to reuse something that might otherwise end up thrown away or melted down.
Looking for a cool alternative pocket watch that’s a little easier to build? Check out [JGJMatt]’s pocket sundial.
