The Enlightenment Turns Light And Noise Into Sound
We’re all familiar with the subtle sounds of electrical equipment present in daily life. There’s the high-pitched whine of a CRT, the mains hum of a poorly isolated audio amplifier, and the wailing screams of inductors. Typically these sounds go unnoticed unless something is malfunctioning or otherwise wrong. However, Quiet Ensemble decided to capture these noises and turned them into a performance they call The Enlightenment.
The basic setup consists of a series of lights, most of which are theatrical in nature. There are spotlights, a series of neons, and even a few bright strobes. Copper coils are used to pick up the stray electrical noises generated by these lights in operation. These noises are then fed to mixers, amplifiers, and other audio equipment to allow the performers to control the audio as they wish.
The end result is a mechanical, and at times, brutal soundscape that wouldn’t sound out of place on the Homeworld soundtrack. Flashing strobes contribute rhythm while the rest of the lights lend their droning and whining to fill out the ensemble.
If it’s a little too niche for your tastes, the Triforium may be more to your liking. Video after the break.
Continue reading “The Enlightenment Turns Light And Noise Into Sound” →
