An aluminium top is shown spinning on a plastic disk in front of a tablet showing the text "2:07:49.5"
Self-Powered Top Spins For Hours
The meaning of Inception’s ending famously revolves around a top which spins forever in dreams, but in real life comes to a stop like any other top. Any other top, that is, except for [Aaed Musa]’s self-spinning top, which can continuously spin for about two hours before coming to a stop.
The one constraint was that every functional component had to be contained within the top’s shell, and [Aaed]’s first approach was to build a reaction wheel into the top. When a motor accelerates a weighted wheel, conservation of angular momentum applies an equal and opposite torque to the motor. The problem is that motors eventually reach a top speed and stop accelerating, which puts an end to the torque. This is known as saturation, and the only way to desaturate a reaction wheel is to slow it down, which counteracts the originally generated torque. [Aaed] originally planned to mount the motor in a one-way bearing, which would let it bleed off speed without producing torque against the rest of the top, but it was rather choppy in practice.
The solution occurred to [Aaed] while watching the aforementioned final scene, when it occurred to him that the wobbling of a top could actually generate rotation. A prototype proved that an off-center weight rotating at a constant speed did successfully spin the top by rotating the center of mass, and after that, it was a matter of incremental testing and improvement. A higher moment of inertia worked better, as did a lower center of gravity and a tip made from a hard, low-friction silicon nitride ball bearing. He made housings out of both 3D-printed plastic and CNC-milled aluminium, which each contained a tiny brushless motor, an electric speed controller, a microcontroller, and a small rechargeable lithium battery.
If you allow for external power, you can make the top itself the rotor of a motor, and drive it from a base. Alternatively, if you levitate your top in a vacuum, it could spin for longer than recorded history.
Squishy Beyblades Made With 3D Printer Fail To Compete In The Arena
When Beyblades first came out a couple of decades ago, they quickly became a fad across Japan and several Western countries. There was a whole ecosystem of parts that you could buy and use to build competitive fighting spinning tops. These days, though — 3D printers are ubiquitous. There’s very little stopping you from printing whatever Beyblade-compatible parts your heart desires, as [JettKuso] demonstrates.
For [JettKuso], the rubber attack tips were a personal favorite. They had high grip on the plastic arena floor and would allow a top to make rapid, aggressive moves that would knock other tops out of the arena. Not desiring to import specific Beyblade parts at great expense, he decided to print some rubber tips and associated parts instead. The result? Squishy Beyblades!
[JettKuso] built various tops with official and custom TPU parts, and put them in battles to see what worked and what didn’t. In many cases, the TPU replacement parts didn’t make a big difference or proved worse than the standard parts. However, when [JettKuso] got crazy, he found one thing that kind of worked. A mega-heavy TPU top blade, which weighed as much as the standard metal rings, was able to successfully win battles against less competitive standard builds.
Ultimately, the video serves as a testament to the developers of the original toys themselves. It’s not so simple to just print up some parts and have them be competitive with the tried-and-tested gear that comes off the store shelves. The experience ultimately gave [JettKuso] a greater appreciation for all the thought that went into the commercial toys. Video after the break.
Continue reading “Squishy Beyblades Made With 3D Printer Fail To Compete In The Arena”
