Desalinating Seawater With Solar And No Brine
Although desalination is very commonly used these days to convert seawater into fresh water, one of the major disadvantages of current approaches is that commercial desalination plants produce a lot of brine, which has to be dumped somewhere ideally without causing major environmental issues. A new solar-thermal method as demonstrated by [Luheng Tang] et al. was published in Light: Science and Applications, with accompanying PR article.
This method is claimed to require no pre-treatment or leave brine, using special panels that wick water across their surface and then use solar radiation to distill this water. This differs from previous similar methods through a special surface treatment that prevents build-up of salts which would require cleaning or replacement.
The salts and other contaminants that would normally end up in the brine slough off these cells and can then be further processed to recover everything from plain table salt to lithium as well as gold, uranium and other substances of interest that are prevalent in seawater.
So far these self-cleaning cells have been tested with water from a number of oceans with a claimed 74% solar-to-vapor conversion efficiency and nearly 100% salt extraction. As always the challenge will be in scaling this up to industrial levels, but so far it looks promising.
44 Layers Of Katharine Burr Blodgett
Whether you realize it or not, Katharine Burr Blodgett has made your life better. If you’ve ever looked through a viewfinder, a telescope, or the windshield of a car, you’ve been face to face with her greatest achievement, non-reflective glass.
Katharine was a surface chemist for General Electric and a visionary engineer who discovered a way to make ordinary glass 99% transparent. Her invention enabled the low-cost production of nearly invisible panes and lenses for everything from picture frames and projectors to eyeglasses and spyglasses.
Katharine’s education and ingenuity along with her place in the zeitgeist led her into other fields throughout her career. When World War II erupted, GE shifted their focus to military applications. Katharine rolled up her sleeves and got down in the scientific trenches with the men of the Research Lab. She invented a method for de-icing airplane wings, engineered better gas masks, and created a more economical oil-based smokescreen. She was a versatile, insightful scientist who gave humanity a clearer view of the universe.
Continue reading “44 Layers Of Katharine Burr Blodgett” →
