NEMA Releases Standard For Vehicle-to-Grid Applications
Vehicle-to-grid (V2G) has been hailed as one of the greatest advantages of electrifying transportation, but has so far remained mostly in the lab. Hoping to move things forward, the National Electrical Manufacturers Association (NEMA) has released the Electric Vehicle Supply Equipment (EVSE) Power Export Permitting Standard.
The new standards will allow vehicle manufacturers and charger (EVSE) suppliers to have a unified blueprint for sending power back and forth to the grid or the home, which has been a bit of a stumbling block so far toward adoption of a seemingly simple, but not easy, technology. As renewables make up a larger percentage of the grid, using the increasing number of EVs on the road as battery backup is a convenient solution.
While the standard will simplify the technology side of bidirectional charging, getting vehicle owners to opt into backing up the grid will depend on utilities and regulators developing attractive remuneration plans. Unfortunately, the standard itself is paywalled, but NEMA says the standard “could put money back in electric vehicle owners’ pockets by making it easier for cars to store energy at night or when turned off and then sell power back to grids at a profit during peak hours.”
We’ve covered some of the challenges and opportunities of V2G systems in the past and if you want something a little smaller scale, how about using a battery that was once in a vehicle to backup your own home?
Grid Batteries On Wheels: The Complicated Logistics Of Vehicle-Grid Integration
At its core, the concept of vehicle-grid integration (VGI) – also called Vehicle To Grid (V2G) – seems a simple one. Instead of a unidirectional charger for battery-electric vehicles (BEVs), a bidirectional charger would be used. This way, whenever the BEV is connected to such a charger, power could be withdrawn from the car’s battery for use on the local electrical grid whenever there’s demand.
Many of the complications with VGI have already been discussed, including the increased wear that this puts on a BEV’s battery, the need for an inherently mobile machine to be plugged into a charger, and the risk of needing one’s BEV and finding its battery to be nearly depleted. Here the cheerful marketing from Nissan and that from commercial initiatives such as Vehicle to Grid Britain makes it sound like it’s a no-brainer once those pesky details can be worked out.
In parallel with the world of glossy marketing leaflets, researchers have been investigating VGI as a potential option for grid-level energy storage. These studies produce a far less optimistic picture that puts the entire concept of VGI into question.
Continue reading “Grid Batteries On Wheels: The Complicated Logistics Of Vehicle-Grid Integration”
