Artwork on the wall is nice and all, but don’t you get bored with it sometimes? What if you could interact with it! That’s just what the [Artless Dodger] decided to do with this old Fidelity Chess Challenger he converted to a wall-playable chess set!
The old Fidelity Chess Challenger is a fun electronic chess set that works by operating on press input. Simply move your piece, press down on its new square and then the computer knows where the piece is. The system is just begging to be hacked into a new form factor.
He’s built the new board from scratch using MDF, and then coated it with faux leather vinyl to give it a more polished look. He’s upgraded all the switches to momentary button switches and then re-soldered all of the connections. This was a bit of a challenge seeing as the original buttons looked like this:
Continue reading “Wall-Mounted Chess Set Lets You Stand And Play”
