Building a bandwidth meter
Here’s an analog bandwidth meter made to look like an old pressure gauge. It’s actually new, but the paper showing the graduated scale was stained in a bath of black tea, then dried in an oven to give it an aged appearance. We think it’s quite effective.
The dial itself is a volt meter driven by an Arduino in much the same way as the multimeter clock. Bandwidth data is pulled from a Linux router, filtered down to the target data using ‘grep’, and sent over the serial connection by a Perl script. Since the meter itself is just waiting for serial data, alterations to the router’s scripting make it easy to represent a count of unread emails, tweets, or whatever data your code can scrape.
[Thanks Ben]
Comments
  1. CGross says:
    Lifehacker takes from HAD, HAD takes from Lifehacker about 5 days late.
  2. ladz says:
    Why not just send a constant serial data stream to a buffer, filter, and op-amp?
    Sending a stream of 0×00 will have a higher RMS voltage than 0xFF.
    seems much simpler.
  3. JeremyC says:
    That is awesome! Nice job!
  4. Anon says:
    Now that’s a beautiful thing.
  5. kristian says:
    @ladz: idk, that sounds like a bit of a hack-solution ;)
    sending data over serial to arduino can also mean sending data via usb, so there’s not necessarily a serial port involved here.
    i checked the writeup, just to be safe: “output to the serial port emulated by the FTDI chip on the Arduino”
  6. matt says:
    SWEET
  7. Harvie says:
    It should be even better if the device was connected directly to ethernet cable (ethernet can pass through it) between router and modem… well we need to find a way how to simply determine bandwith from ethernet cable… i guess there’s at least way to count packets per second or some similar – almost analog solution.
  8. Simon says:
    Looks like a current-limiting resistor is needed between the Arduino PWM pin and the transistor. Perhaps everything getting hot is part of the steampunk effect!
  9. Evan says:
    What would be cool is to link this to cpu useage rather than bandwidth.
  10. Nice work with the meter , but adding the diode across the coil ,and driving it with IRL series MOSFET should work better.
    @Harvie . There is a way , at least with every good router or switch – the SNMP protocol . I made such device to work with my Cisco 2610 a year ago using a Wiznet chip and an AVR microcontroller .
  11. Friction57 says:
    Can anyone provide a solution for this where instead of an analog meter, it’s connected to a digital number display (like an alarm clock display) that will show you bandwidth use across any spectrum?
  12. mrlinconnu says:
    Hi everybody,
    Is it possible to give more details on how bandwith value are recovered from the PC ?
    It’s wrote that datas are pulled from a linux router ?
    Is it possible to get the same function from a basic provider XDSL modem ? Or in this case the solution is it to use software programmes ?
    In a windows how can I get the real time bandwith usage ?
    Many thanks for some links…
  13. DarkFader says:
    And then you get a feeling that someone is downloading just at the moments you’re not looking :)
    I will try to compile istatd for my linksys router. Now if only I could subtract the bandwidths… would be nice to know what my dad and brother are using. I already can see which sites they visit :)
  14. skytee says:
    Actually, the gauge is old. Manufactured in 1908.
  15. Name (required) says:
    Nice, this was also shown on the 27c3.
WordPress.com Logo
Twitter picture
Facebook photo
Connecting to %s
