Clock display taller than you is just what your living room has been missing
huge-countdown-clock
Sure, it’s time to get the countdown clocks ready to ring in the new year, but why limit it to just one night? If you end up building a six-foot digital display you can count down trivial events; like the remaining seconds of freedom before you have to pimp yourself out in that drab cubicle.
This seven-segment display is homemade and boasts six full-sized digits and two smaller digits with each pair separated by colons. You have probably already guessed that the construction was greatly simplified by using LED strips rather than individual components. This is part of the reason for the size of the display. The strips can be cut, but only down to a minimum of 3 LEDs per segment. That explains the small digits, with their larger siblings doubled in size. But there is a benefit to this constraint, it means that current limiting is already taken care of for you.
The main assembly is a wooden frame surrounding two polycarbonate sheets. The LED strips are sandwiched between those sheets, with segment and digit driver buses exiting a one point on the side. The build doesn’t detail a driver for the display but it shouldn’t be hard to find a multiplexing example that will serve the purpose.
Comments
  1. joeisi says:
    I would like to disagree with the title. I am definitely taller than this module.
  2. NewCommentor1283 says:
    sweet display,
    with one _that_ big makes me want to make it
    time and VU at the same time
    ie connect VU chip (outs) to dimming connections
    (of each digit)
    XD
  3. Frank Cohen says:
    I think you mean whore yourself out Mike.
WordPress.com Logo
Twitter picture
Facebook photo
Connecting to %s
