Sure, it’s time to get the countdown clocks ready to ring in the new year, but why limit it to just one night? If you end up building a six-foot digital display you can count down trivial events; like the remaining seconds of freedom before you have to pimp yourself out in that drab cubicle.
This seven-segment display is homemade and boasts six full-sized digits and two smaller digits with each pair separated by colons. You have probably already guessed that the construction was greatly simplified by using LED strips rather than individual components. This is part of the reason for the size of the display. The strips can be cut, but only down to a minimum of 3 LEDs per segment. That explains the small digits, with their larger siblings doubled in size. But there is a benefit to this constraint, it means that current limiting is already taken care of for you.
The main assembly is a wooden frame surrounding two polycarbonate sheets. The LED strips are sandwiched between those sheets, with segment and digit driver buses exiting a one point on the side. The build doesn’t detail a driver for the display but it shouldn’t be hard to find a multiplexing example that will serve the purpose.
Subscribe for weekly videos
I would like to disagree with the title. I am definitely taller than this module.
Then your living doesn’t need it?
Same, I’m 6’8″, so I guess this article isn’t meant for me!
Honey, I Shrunk the Engineers
sweet display,
with one _that_ big makes me want to make it
time and VU at the same time
ie connect VU chip (outs) to dimming connections
(of each digit)
XD
I think you mean whore yourself out Mike.
