Decoding NOAA weather radio with an Arduino
The National Oceanic and Atmospheric Administration is responsible for broadcasting the signals used in weather radios. They use a protocol called Specific Area Message Encoding (SAME) and [Ray Dees] recently published an Arduino library that lets you decode the SAME message packets.
He doesn’t provide a method of tuning the radio signal, but at first you can use the … Read the rest
