Add Bluetooth Audio To Your GPS/etc
[sudija] wrote up a nice instructable on adding bluetooth audio output to a tomtom gps unit. It’s not too technically advanced, but you’ll have to add an audio jack if your gps lacks one. This looks like a great way to turn a cheaper unit into something suitable for a motorcycle rig.
4 thoughts on “Add Bluetooth Audio To Your GPS/etc
  1. This is one of those “really obvious” hacks that you totally wish you had thought of before. I can see myself using something like this for a few different things…
  2. Planning to hack up some cheap bluetooth headphones, putting them to speakers instead, hiding them under a chair in a lecture theatre, then playing “The Final Countdown” at full volume at the end of lectures.
  3. thehackinator: /hiding them *under a chair* in a lecture theatre, then playing “The Final Countdown” at full volume at the *end of lectures*./
    Why wait till end of the lecture? Play farting sounds when the lecture is on! :-D
Leave a Reply to WeirdguyCancel reply
