Machinecollective.org is bringing rapid prototyping to every day artists and hackers. We’ve covered similar interfaces like the monome, MIDIbox, and Stribe. Machinecollective allows you to make your own input system using multiple blocks to get exactly what you want. The setup allows you to fit pretty much anything in a block that you can think of. They’re developing potentiometers, slide potentiometers, button grids, toggle switches, LCD’s, FSR/LDR’s, velocity sensitive pads, and touch screens.
Currently, they support software enviroments like: Processing, Max/MSP, VVVV, and Adobe Flash. That list will undoubtedly grow as the community plays with it. They envision the hardware connecting via MIDI, OSC, RS232, TCP/UDP, DMX, or USB.
They encourage others to design their own inputs. Community members can share modifications and designs, though there isn’t a forum or store yet. If you design a setup that you really like, they can even fabricate a single unit for you. Keep your eyes on this one, it could be a real hit.
A similar idea for general gadgetry can be seen over at Bug Labs. Starting with a base unit, you can add different input and output modules to create various useful functions. They currently offer GPS, a camera, a display, and motion sensing. Mix and match to make your dream gadget.
Wow, these things just take all the work (and admittedly some of the fun) right out of building stuff and just leaves you with creating and coding. That’s awesome as it leaves more time for beer!
As interesting diy music devices are from a hardware standpoint, they’re almost useless from a musical perspective. If it needs software to make sound, its impractical from a recording or live performance standpoint. Until these kits have standard MIDI in/out that can connect to sound modules and MIDI interfaces, they’re doomed to be novelty items.
