Curious Inventor pointed out a cache of training materials provided by IPC. IPC is a trade organization that publishes standards for producing and evaluating electronics. They’re great looking full color guides that most hobbyists will probably never get their hands on. They have low resolution video demos as well. Go snag them now in case they go away!
25 thoughts on “Professional Soldering Guide”
Leave a Reply to Dan FeketeCancel reply
humm, I wonder how much longer the site will work.
“Go snag them now in case they go away!”
looks like it’s going down already.
Heh, we just tossed a TON of the IPC-610C books at work. We don’t use those standards anymore, we’ve gone to the Rockwell Standards. Much tighter, but produce a much better product.
aargh no! :(
already gone..
can sb please send me the smt-guide?
apfelmuskingatgmxdotde
or maybe sb will upload it to a freefilehoster
for everybody?
Maybe someone would be kind enough to make a torrent of the complete set ?
Did this site really just get a hackadotting?
The site didn’t initially load for me either. Just hit refresh a couple of times and it should load, it did for me twice already.
Pretty sweet eh? :D
Its not totally down on my visit, just very, very slow. (.1kB/s)
looks like we killed their bandwidth.
you can access is a lot better through the CoralCDN: using this link:
http://training.ipc.org.nyud.net/demos/
I got 23 out of 30 that I downloaded, Ill upload it in a few hours.
Here’s what I’m using. This should just grab the PDFs and videos (so far so good at about 3/4 of them). Its a slow connection, but it’s chugging along…
wget –no-clobber –random-wait –wait=5 –retry-connrefused –no-directories –recursive –level=2 –accept pdf,wmv,mpg,mpeg,avi –reject html,htm,txt
http://training.ipc.org/demos/
Yeah, we killed them – probably non of their site works well. I was only able to download “DRM-PTH-D through hole solder joint evaluation”.
Artur92710, which ones you still don’t have? I will be trying with those first.
By the way.. Has anyone noticed that Curious Inventor developed a really nice soldering guide?
http://www.curiousinventor.com/guides/how_to_solder
2 days later and still down!? I managed 8 of the PDF’s and 1 video before it blew up…
Ok then, how about uploading what we’ve got somewhere?
Unfortunately I was unable to download anything more then “drm-pth-d through hole solder joint evaluation”, but it’s a good start I think.
Here it is:
http://rapidshare.com/files/166100957/drm-pth-d.pdf
I saw this and had to send an email to my friend “check this out! the curve from top left to bottom right on a front view exactly matches the curve from left to right on a side view (towards the point of refrence). I mean how do they get the surface tension to make such a perfect curve, when I pull my iron away I always get solder that tries to stick to my iron and then cools in ugly looking points”
if anyone has these cats or other howto guides to solder this well please please send me an email.
sirus20x6 at gmail dot com
could somebody email me the soldering guides as well? thnx.
ctpatt at gmail dot com
C’mon guys, upload something like I already did…
hi,
someone said it was going to post a torrent, any news about that??
So sad…. they’re still down.
sorry it took so long. Megaupload was giving me error 2.
http://www.megaupload.com/?d=47K7CMVG
cool, hackaday has an Effect.
thanks arthur
Arthur, great job man, thanks!
