Saying that [Ian] had some overheating issues with his iMac G5 would be an understatement. After losing three hard drives due to heat he decided to do something about it. The first step was replacing the thermal paste with Arctic Silver. The solution for the hard drive was a little more unorthodox.
[Ian] picked up a 320GB Western Digital Caviar Blue drive because of its very low noise rating. He used rubber grommets to mount it outside the case and ran SATA data and power extension cables through a quarter inch hole to the motherboard. He mentioned to us that the cutout seen above the drive is from a previous mod.
This certainly will fix an overheating problem but it doesn’t do much for the sexy style we’re accustomed to with Apple hardware.
