Arduinome With Many Pots
[Aggaz] added 16 potentiometers to his Arduinome.The Arduinome is a monome clone based around the Arduino as a microprocessor. We seen some Arduinome builds in the past but [Aggaz’s] work augments the physical interface.
Potentiometers used in circuit bending allow for manipulation of the sounds coming out of the circuits. In this case the pots are connected to the microcontroller instead of the sound generation circuitry which means you can do whatever you want with them depending on how creative you are with the code. So far he’s just starting to get the new set of interfaces to play nicely over the serial connection. This could end up being quite popular as it only requires the addition of a multiplexer IC, the potentiometers, and the knobs.
10 thoughts on “Arduinome With Many Pots
  1. I just started my arduinome build last night. With this I might have to rethink my case design for future upgrade, very cool.
  2. don’t forget to check out the doepfer potentiometer to midi ‘pocket electronic’ they have for sale – might save some time if you need something quick
  3. Bliptronic 5000 at Thinkgeek.com
    $50.00 and worth it for parts alone.
    I have been having fun with it since xmas but am cracking it open today and see about some mods.
    It is “affordable to ruin” since the wife has another one on the way hehe.
    Give it a peek. not trying to spam.
    Might help with ideas or be a shortcut.
    http://www.thinkgeek.com/electronics/musical-instruments/c4e1/
    I’m already thinking of at least clocking to MIDI since its bpm selection leaves a lil something to be desired. Bends look pretty easy but not super spectacular. But… daughterboards are always a nice thing heh.
Leave a Reply to marcCancel reply
