Google Bike Hack, Quick And Dirty
Many of the projects we post are so well thought out and engineered, they could hardly be called “hacks”.  This one, however, falls neatly into the hack category. [Dave] wanted his very own exercise bike hooked to Google maps. Instead of setting up a control system and writing software to control Google maps, he simply hacked a USB game controller. He wired a magnetic switch directly into the board, where the “up” button is. Then he mounted the switch so that it would be triggered each time he rotated the pedal.  Though he only has the forward movement done right now, it would be pretty easy to set up a couple more switches at the base of the handle bar for left and right.
While the experience may not be quite as nice as the more complicated one, aside from head tracking, it isn’t that far off.
10 thoughts on “Google Bike Hack, Quick And Dirty
Your email address will not be published. Required fields are marked *
