[Nick] tipped us off about a guide to unlock extra features on Panasonic televisions. The hack works on the G10 models of plasma TVs and uses the service menu to gain access to the EEPROM memory. With a few quick steps you can change some data with a built in hex editor, unlocking several new settings menus, or bricking your entertainment centerpiece. We’ve seen some Samsung TV hacking in the past and hope that with increased processing power in today’s models we’ll someday see consumer TVs available with open-source firmware so that we can integrate of our favorite entertainment software.
@mac @digitaldazz
Well done for exploring this hack.
I understand that the hack effectively runs the G10 internal software as a G10E (European) rather than G10B (UK) thus loosing the Freeview/ Freesat EPG etc.
Question:
Does changing the HEX back to “03” from “20” return the G10 to its G10B status and thus the Freeview/ Freesat EPG works as normal?
I use external hard disk recorder with built in turners and I’m not fussed about loosing the EPGs on the TV. I would like to return the TV back to normal conditions at a later date though.
There is a lot of talk at AV Forums about this hack. It’s apparant that Panasonic have removed these advanced WB/ Gamma features from the G10B just to market position the V10 and it’s THX setting. The V10 about £300 more than the G10B.
I have a TX-P50VT20B
Can I hack it and upgrade the software ???
@mac, if you click my name above you’ll get to my website, which will redirect to my blog, which has my profile info on the left hand side, which contains a link to my email :-)
Let’s see bots find that!!!
@EuphoricMonkey
Actually it changes it to a GW10 so as not to to lose the satellite tuner:)
Yes, it’s reversible if you wish.
@ Peanut – Thanks, I’ll be in touch
mac sent me the info as a Word document – have uploaded it here:
http://drp.ly/qFKeA
hope it helps!
Hi all..
a quick question (@mac? :))
with g15E it’s possible to unlock the dvb-s without choosing germany/austria/switzerland?
I cant understand if you can unlock the satellite menu too or what
@Frisi
The only viable alternatives to change the device identifier to were the G10E or GW10. G10e doesn’t feature a sat tuner afaik so I went for the GW10. It was my understanding that Panasonic only enabled the sat services in those countries although I’m not 100% on this. Still it works:)
G15B – G15E would perhaps be different in that the sat tuner may well be available in all countries.
@mac
g15e got sat tuner, but if you dont choose germany/austria/switzerland you cant receive sat channels… But if i set for example “germany”, the guide+ dont work and i lose the default channel numeration for my country (italy).
Panasonic is selling a tv, saying that include dvb-t and dvb-s… but they dont tell you that you can’t use dvb-s in italy.. it’s ridicolous.
I’m trying to fix this, maybe with a firmware hack or something that can allow me to unlock the dvb-s tuner menu :(
Frisi – sorry I misunderstood your earlier post :)
I’ll have a look in to it but I don’t think it’s hackable :(
TX-P42G15B UK TV – Following the guide through to the memory editor at line 40 I have:
19 06 19 00 31 02 02 20
i.e. 02 not 03 at position 6.
Why would this be different??
As there is a difference I have not proceeded to change to 0F (for the G15) until I can get some feedback regarding his.
@ Kalaglow
It’s different on a G15 as that value is the device identifier. 0F is the device identifier for a G15e so changing it to that will enable the advanced menus.
ITV HD is now viewable with a manual tune for those that have already hacked btw.
@mac
On the 9th Feb you mentioned to get the freesat to work you need to restore to factory conditions and select Germany, Switzerland or Austria.
Can I just confirm whether this is just for G15’s or is it for both G15 and G10 sets?
Also, could you give me a pointer on how to retune BBC HD & ITV HD.
I haven’t actually got my G10 yet but this sounds like it would be very useful to do from day one.
Thanks
Ehruell – Yes to renable the sat tuner, after the hack, you need to do a factory reset and change your location to one of those countries.
That is true of g10 and G15, probably the V10 too but noones tries it on a V yet.
I don’t use the sat tuner at the mo so I’m not the best to ask. Join Av Forums and post a question in either the G10 or G15 thread as I know there are people there who have done it. Failing that, I’ll try and dig out the info later.
ITV HD (must be transmitting to tune)
Use the “Other Sat. Channels” tuning menu. Use the Manual tuning option and ITV HD is at Freq. 11.427, polarisation H, symbol rate 27.5.
BBC HD
Select DVB-S
Go to menu then setup
Then manual Tuning
and enter the following
(28.2° East)
Frequency: 10.84700 GHz (don’t worry about the decimal point)
Vertical polarisation
Symbol rate: 22.0 Mbaud
Service ID – 6940
After you have entered the details, press OK to start a scan. After a few second it will find it. BBC HD will be automatically added at the bottom of your channel list. You just need to add it to favourites after that.
Thanks very much for your help!
OH MY GOD. To the author of this hack, please can we have more hex hacks for other models!? Eg. 2008/2009 models??
I’ve been wanting to fix the gamma for a very long time on my pana 50PX80A. I always suspected something was possible in the memory editor, now finally something comes to the surface but it’s not for my model AHHHHHHH :O
I’m not so sure, but I’m willing to reconsider because you are making some fabulous points.
Recently hacked my G10 fine with no problems.
I would like to update my TV to the latest firmware though, can I just follow the guide and revert back to the default settings in HEX then try to update or is this a bad idea?
I have the 50″ with the latest G10 firmware 1.612
Is this hack ok with the tv firmware, seeing how it is UK only firmware?
Hi, I think I enetred a wrong value for my G15 and all I have is a blank screen. Guess it is bricked! Is there any way back from this?
can I hack my txp42g20b with it ?
you can find it out if it work, the same line 00000040 applies. change 06 to 09. can you brick your plasma or not.. and.. report back here results. ;)
1907190071060220 <– UK model 42G20B
1907190071090220 <– EU model 42GW20
Any news about this for new S20E or U20E modeels?
Unfortunately I own an panasonic tx-32led7fm lcd tv and strangely in the tv menu there is an open source GPL licence agreement referring to the open source software in the tv.
also curiously, the tv sports an SD card reader that doesnt seem to do anything. It would be sweet to be able to load custom firmware through that sd slot…
Any news about this for tx-l37v10b model?
Amazing hack! I even got some of the Sky channels for free!
Perhaps the best one is to lose weight quickly and safely.
between half the price or even a tenth of the price of other popular diets
and programs. For me, Sparkpeople provided the kick in the rear I needed to
get moving and get active. Still wondering what is the h
– CG diet plan and is it right for you. The majority of low
calorie weight loss plans out there has a big issue and that is they have an inclination to decrease your fat burning capacity in this degree that it is frequently out of the question not to put on weight again after
you concluded your diet plan.
I was able to access the hex editor on my Panasonic TV. Can someone help me fix my overscan through the editor? Model no. TX-32LE8M
