Control A TV With GLCD Commands
This hack lets you use a TV in place of a graphic LCD screen. But we like to think of this less as a replacement for a GLCD and more of a simple way to get your information onto a television. A PIC 18F452 acts as a translator between the GLCD parallel inputs and a composite video output. There are some malformed image links on the page which we’ve fixed and linked to after to the break so that you can take a look at the schematic, component layout, and PCB artwork. The assembler code and hex file are available for download but you’ll need to register to get access to them.
Working image links:
[Thanks Flacoclau]
7 thoughts on “Control A TV With GLCD Commands
Leave a Reply to HackerK Cancel reply
