DelFly2 And DelFly Micro
The video you see above is the on board footage of the DelFly2 autonomous ornithopoter robot. Weighing 16 grams, it carries a small camera and can provide a live feed. If you’re amazed at the tiny size and weight of the DelFly2, check out the DelFly micro, video after the break, that weighs 3 grams. Remember when we thought 17 grams was small for an ornithopter?
All processing for the DelFly2 is done at a base station and transmitted to the flying bot to keep the weight down. The team also had to create their own brushless motor that runs at 60% efficiency and weighs only 1.6 grams. The 130mAh battery can sustain 15 minutes of horizontal flight or 8 minutes of hovering.
[via BotJunkie]
15 thoughts on “DelFly2 And DelFly Micro
  1. Preferably harvested from ambient WiFi signals, though I suspect the power density just wouldn’t be worth the weight in additional hardware on such a small device.
Leave a Reply to fartface Cancel reply
