Wireless Fiber Optic Mood Lighting
ceiling_mounted_starfield
There’s something calming about looking up into the night sky and seeing an array of shining stars off in the distance. [Marou] is a big fan of stargazing, but sometimes conditions are not optimal, so he decided to bring the stars inside.
His idea was to build a ceiling lamp that didn’t bask the room with light, but rather one that reproduced the peaceful twinkle of the night sky. He covered a wooden table with dark fabric and drilled a ton of tiny holes into the surface. He fitted the holes in the table with two big bundles of optical fibers since one bundle couldn’t quite cover the entire thing.
To light the cables, he built a pair of 4-LED illuminators, which contain red, blue, green, and white LEDs. Each light source is controlled via an Arduino which takes its direction from [Marou’s] infrared remote.
While the idea isn’t new, the implementation is pretty cool. At first we were expecting a small lamp, but anchoring an entire table to the ceiling as a light panel is definitely something we hadn’t seen before.
If you want to build something similar in your own living room, [Marou’s] Arduino code is free for the taking.
8 thoughts on “Wireless Fiber Optic Mood Lighting
    1. Wireless as in wirelessly controlled using IR:
      “Each light source is controlled via an Arduino which takes its direction from [Marou’s] infrared remote.”
  1. I believe I saw a commercial product for the same thing, however it involves drilling little holes in your ceiling…
    This is a good way to not have to worry about too much permanent damage :)
Leave a Reply to WhatnotCancel reply
